I’m using the map feature to redirect from one path to another looking up a list in an external file. This is how that work:
http-request redirect code 301 location %[capture.req.uri,map(/etc/haproxy/my.map)] if { capture.req.uri,map(/etc/haproxy/my.map) -m found }
Now I need to enhance that such that the key which is capture.req.uri
in the above example will now be the domain AND the path so I wonder how I could concatenate those 2 parts (hdr(host)
and capture.req.uri
) into one string to work as the key for the lookups.
