trococ
1
I would like to log if the response is compressed by haproxy or not
this is an example config:
http-response set-var(txn.comp) yes if { res.comp }
http-response set-var(txn.comp) no unless { res.comp }
log-format compress\ %[txn.comp]
of course it’s not working.
How can do that?
jerome
2
you must use a sample fetch after http-response set-var, use the following
http-response set-var(txn.comp) str(yes) if { res.comp }
http-response set-var(txn.comp) str(no) unless { res.comp }
https://cbonte.github.io/haproxy-dconv/2.0/configuration.html#http-response%20set-var
you get the content of the variable with var(txn.comp) so write your log-format line like this:
log-format compress\ %[var(txn.comp)]
https://cbonte.github.io/haproxy-dconv/2.0/configuration.html#var
trococ
3
thank you so much, it works
