How to disable TLS v1.0 & v1.1 in HAProxy?
For our application, it shows TLS v1.0 & v1.1 are enabled. We need to disable it.
We checked the haproxy config file file & added this:
frontend ssl
bind 0.0.0.0:443 ssl crt /etc/haproxy/ssl_cert.pem ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256 force-tlsv12 ca-file /etc/haproxy/ssl_ca_cert.pem no-tlsv11 no-tlsv10 no-sslv3 verify optional
But still, it shows as enabled.
What are we missing here? Let us know if you need the complete config file.
Thanks.
Here we use
ssl-default-server-options no-sslv3 ssl-min-ver TLSv1.2
And result seems OK BUT we get a warning at startup :
no-sslv3/no-tlsv1x are ignored for server 'my_server'. Use only 'ssl-min-ver' and 'ssl-max-ver' to fix.
You can get rid of it with a line like
ssl-default-server-options ssl-min-ver TLSv1.2 ssl-max-ver TLSv1.2
Help it can help :slight_smile:
This syntax does not work in version 1.5.8
Haproxy 1.5 is quite old. Not sure if still maintained.
You should consider to uprgrade.
Regarding your issue, you have to check the doc to find the appropriate config
This configuration is correct, the configuration may not be properly applied (old haproxy instance running in the background with old configurations), you may hit a bug, or your measurements may not be accurate.
Provide the output of haproxy -vv and openssl outputs from the haproxy machine (not a far end device crossing firewalls and other security devices, you may have SSL intercepting devices in the path), but 127.0.0.1:443 :
openssl s_client -tls1 127.0.0.1:443
openssl s_client -tls1_1 127.0.0.1:443
openssl s_client -tls1_2 127.0.0.1:443
Please find the haproxy version screenshot .
1.For This we getting error after run those below commands.
Command Not Found
2.But We run the command openssl for cipher we getting output below.
ravi@admins-/ % openssl s_client -connect developernexus.ob.globalbank.sbi:443 -cipher “EDH”
CONNECTED(00000005)
depth=2 C = US, O = “Entrust, Inc.”, OU = See Legal and Compliance, OU = “(c) 2009 Entrust, Inc. - for authorized use only”, CN = Entrust Root Certification Authority - G2
verify return:1
depth=1 C = US, O = “Entrust, Inc.”, OU = See Legal and Compliance, OU = “(c) 2012 Entrust, Inc. - for authorized use only”, CN = Entrust Certification Authority - L1K
verify return:1
verify return:1
Certificate chain
0 *****************
i:/C=US/O=Entrust, Inc./OU=See www.entrust.net/legal-terms/OU=(c) 2012 Entrust, Inc. - for authorized use only/CN=Entrust Certification Authority - L1K
1 s:/C=US/O=Entrust, Inc./OU=See www.entrust.net/legal-terms/OU=(c) 2012 Entrust, Inc. - for authorized use only/CN=Entrust Certification Authority - L1K
i:/C=US/O=Entrust, Inc./OU=See www.entrust.net/legal-terms/OU=(c) 2009 Entrust, Inc. - for authorized use only/CN=Entrust Root Certification Authority - G2
2 s:/C=US/O=Entrust, Inc./OU=See www.entrust.net/legal-terms/OU=(c) 2009 Entrust, Inc. - for authorized use only/CN=Entrust Root Certification Authority - G2
Server certificate
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
subject=***********************
issuer=/C=US/O=Entrust, Inc./OU=See www.entrust.net/legal-terms/OU=(c) 2012 Entrust, Inc. - for authorized use only/CN=Entrust Certification Authority - L1K
Server Temp Key: DH, 1024 bits
SSL handshake has read 4849 bytes and written 302 bytes
New, TLSv1/SSLv3, Cipher is “*******************”
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : *****************
Session-ID: ********************
Session-ID-ctx:
Master-Key: ****************************
Start Time: 1645684131
Timeout : 7200 (sec)
Verify return code: 0 (ok)
HTTP/1.0 408 Request Time-out
Cache-Control: no-cache
You need to run those commands on the haproxy box against 127.0.0.1:443. If you are missing the local openssl tool, install it.
ssl-default-bind-options no-sslv3 no-tlsv11 no-tlsv10
Worked for me!
Sorry to re-activate the conversation again, I’m using HAproxy 2.4.x and tried all possible syntax but still not disabling tls1.1 and 1.0, Am I missing something?
It also depends on the openssl release, you are probably running v3.0.
You can append :@SECLEVEL=0 to ssl-default-bind-ciphers or manually edit your openssl.cnf to lower the SECLEVEL to 0.
Forget what I said, I got the question wrong.
Thank you for the reply @lukastribus could you give me the exact syntax for openssl.cnf? I’m using openssl 1.1.1
I’m sorry, I realize I got the question wrong.
Please refer to post #5 in this thread.
If this doesn’t work for you, provide the outputs request in that post.
That didn’t work unfortunately:
HAProxy version 2.4.4-acb1d0b 2021/09/07 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.4.4.html
Running on: Linux 3.10.0-1160.36.2.el7.x86_64 #1 SMP Wed Jul 21 11:57:15 UTC 2021 x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_PCRE=1 USE_OPENSSL=1 USE_ZLIB=1 USE_SYSTEMD=1
DEBUG =
Feature list : +EPOLL -KQUEUE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 -CLOSEFROM +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS -OT -QUIC -PROMEX -MEMORY_PROFILING
Built with gcc compiler version 4.8.5 20150623 (Red Hat 4.8.5-44)
h2 : mode=HTTP side=FE|BE mux=H2 flags=HTX|CLEAN_ABRT|HOL_RISK|NO_UPG
: mode=HTTP side=FE|BE mux=H1 flags=HTX
: mode=TCP side=FE|BE mux=PASS flags=
Available services : none
[FCGI] fcgi-app
And haproxy.cnf
ssl-default-bind-ciphers TLS13-AES-256-GCM-SHA384:TLS13-AES-128-GCM-SHA256:TLS13-CHACHA20-POLY1305-SHA256:EECDH+AESGCM:EECDH+CHACHA20
ssl-default-bind-options no-sslv3 no-tlsv10 no-tlsv11
pidfile /var/run/haproxy.pid
maxconn 4000
CONNECTED(00000003)
139630862251920:error:1409442E:SSL routines:ssl3_read_bytes:tlsv1 alert protocol version:s3_pkt.c:1493:SSL alert number 70
139630862251920:error:1409E0E5:SSL routines:ssl3_write_bytes:ssl handshake failure:s3_pkt.c:659:
no peer certificate available
SSL handshake has read 7 bytes and written 0 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.1
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
Krb5 Principal: None
PSK identity: None
PSK identity hint: None
Start Time: 1677271775
What makes you think that the configuration doesn’t work, specifically?
As per the output you provided, TLSv1.1 is NOT negotiated.
Thank you so much @lukastribus. I was getting confused with haproxy -vv output which says the OpenSSL library supports: TLSv1.0 TLSv1.1 TLSv1.2 TLSv1.3.
Thank you so much for your help.
