How to log HTTP headers when doing SSL-bridging?
Hi
I’m interesting in logging http headers, in order to log Source IP etc.
My “/etc/rsyslog.d/haproxy.conf”
$ModLoad imudp.so
$UDPServerAddress 127.0.0.1
$UDPServerRun 514
local0.* /var/log/haproxy-traffic.log
local0.notice /var/log/haproxy-admin.log
The log part of haproxy.conf
log 127.0.0.1:514 local0
And finally the headers I wan’t to capture:
frontend MyFrontend
http-request set-header X-MS-Forwarded-Client-IP %[src]
In advance, thanks
'Adder
When you decrypt and rencrypt SSL, you access HTTP headers normally, there is no difference with or without SSL.
If the situation is more complex, please provide the full configuration.
I’m guessing here but isn’t the problem that because you have HAProxy adding those headers it makes them harder (Impossible…?) to log…
I did a very quick check on my side and I cannot get HAProxy to log headers that it adds but I have no problem if they were added upstream before HAProxy.
I’m trying to use:
capture request header X-Forwarded-For len 15
And a custom log format:
log-format %[capture.req.hdr(0)]:%cp\ [%t]\ %f\ %b/%s\ %Tq/%Tw/%Tc/%Tr/%Tt\ %ST\ %B\ %CC\ %CS\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ {%hrl}\ {%hsl}\ %{+Q}r
However, it might just be a mistake in my config so my apologies if I’m being stupid or unhelpful.
That’s right, you probably cannot access headers you are setting yourself, but then again, does that make sense in the first place?
Hi Guys
And thanks :slight_smile:
We are using keepalived, and the full config is as follows:
maxconn 6000
maxcompcpuusage 90
maxcomprate 0
nbproc 1
ssl-server-verify required
user root
group root
ssl-default-server-options force-tlsv12 no-tls-tickets
ssl-default-server-ciphers ECDH+AESGCM:ECDH+CHACHA20:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSS
ssl-default-bind-options force-tlsv12 no-tls-tickets
ssl-default-bind-ciphers ECDH+AESGCM:ECDH+CHACHA20:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSS
maxconn 2000
timeout check 50000
timeout http-keep-alive 50000
timeout http-request 50000
peers adfslb01_02
peer adfslb01 10.0.1.161:8081
peer adfslb02 10.0.1.162:8081
frontend ADFSFrontend
bind 10.0.1.160:80
bind 10.0.1.160:443 ssl crt /etc/haproxy/StarFull.pem
http-request set-header X-MS-Proxy HAProxy
default_backend ADFSBackend
backend ADFSBackend
option httpchk GET /adfs/ls/idpInitiatedSignon.aspx
http-check expect status 200
server adfs01 10.0.1.101:443 ssl verify none check check-sni adfs.mydomain.com sni ssl_fc_sni inter 3s rise 2 fall 3
server adfs02 10.0.1.102:443 ssl verify none check check-sni adfs.mydomain.com sni ssl_fc_sni inter 3s rise 2 fall 3
stick-table type ip size 20k peers adfslb01_02
backend Stats
bind :9000
stats hide-version
stats refresh 10s
stats show-desc ADFS
stats show-legends
stats auth Admin:Password
stats uri /Stats
stats scope ADFSFrontend
stats scope ADFSBackend
stats scope stats
Does it make sense logging the things we are setting ourself? properly not, but it’s demanded :slight_smile:
On the other hand it might end up being outdated, as we made the config due to demand for Adding a specific header… and now we are most likely going to make it via a transparent HAProxy instead - we use that in front of the WAP servers, funny enough the same setup won’t work with the ADFS servers so guess that’s my next task :smiley:
Best regards
'Adder
The back end would be a proper place to log the headers except if you do not have access to it.
you have to use http-request capture to capture headers you set on the same haproxy.
https://cbonte.github.io/haproxy-dconv/2.0/configuration.html#http-request%20capture
ie:
http-request set-header foo bar
http-request capture hdr(foo) len 3
they will show up in between {} in the default httplog format.
thanks - I will further into it
