frontend ft_http
bind :80
stats auth admin:password
stats refresh 30s
stats show-node
stats uri /haproxy_adm_panel
stats admin if TRUE
# Use General Purpose Couter (gpc) 0 in SC1 as a global abuse counter
# Monitors the number of request sent by an IP over a period of 10 seconds
stick-table type ip size 1m expire 10s store gpc0,http_req_rate(10s)
acl white_list src 127.0.0.1 109.109.134.237
# refuses a new connection from an abuser
tcp-request content reject if { src_get_gpc0 gt 0 } !white_list
# returns a 403 for requests in an established connection
http-request deny if { src_get_gpc0 gt 0 } !white_list
default_backend bk_http
backend bk_http ###HOSTS ARE ADDED TO THIS BACKEND BY DEFAULT
# If the source IP sent 10 or more http request over the defined period,
# flag the IP as abuser on the frontend
acl abuse src_http_req_rate(ft_http) ge 10
acl flag_abuser src_inc_gpc0(ft_http) ge 0
# Returns a 403 to the abuser
http-request deny if abuse flag_abuser
server webserver1 172.18.2.86:80 check
This successfully rate limits the http requests but
1- white list doesn’t work.
2- rate limit is global and not per endpoint.
