I’m using HAProxy 1.8.8 on Ubuntu in front of my IIS web servers to load balance and bind SSL certificates. So far so good on this.
The problem is that our wildcard SSL certs will not cover “www.myclient1.example.com” but only “client1.example.com” (wildcard ssl cert does not cover the www part, only *.TLD).
There’s too many subdomains to get get a SSL cert for each www.client(#).example.com.
So I need to remove the www part before HAProxy binds to the SSL cert. How do I accomplish this?
HAProxy is also binding to other domains which also needs the www part removed.
Note for below. I had to replace the dot with underscores as forum wouldn’t allow me to post more than 2 links.
What I mean’t was to say I just wanted to strip the www from all requests (eg. www_client1_example.com) so a wildcard SSL cert for (wildcard)_example_com would work (before SSL handshake). The wildcard cert will cover client1_example_com but not www_client1_example_com. Not feasible to acquire each and every SSL cert (even if free from Let’s Encrypt) for each sub domain.
I hope this makes sense.
Victor
# chroot /var/lib/haproxy
chroot /etc/haproxy
maxconn 50000
lua-load /etc/haproxy/acme-http01-webroot.lua
frontend www-http
maxconn 50000
bind 10.250.50.100:80
# Rule to redirect to Lua plugin
acl url_acme_http01 path_beg /.well-known/acme-challenge/
http-request use-service lua.acme-http01 if METH_GET url_acme_http01
# Use the special non http to https forwarding backend if traffic from Let's Encrypt
use_backend verification if url_acme_http01
default_backend www-backend
frontend www-https
maxconn 50000
bind 10.250.50.100:443 ssl crt /etc/haproxy/certs/churchwebsitesplus.com.pem crt /etc/haproxy/certs/completewebpagedesign.com.pem crt /etc/haproxy/certs/dynamicdemo11.com.pem crt /etc/haproxy/........(many many more....)
backend verification # does not redirect to https to allow verification to work with Let's Encrypt without errors
option httpchk GET /
http-check expect string alive
server web1 10.250.30.1:80 check fall 3 rise 2
server wwb2 10.250.30.2:80 check fall 3 rise 2
server web3 10.250.30.3:80 check fall 3 rise 2
server web4 10.250.30.4:80 check fall 3 rise 2
server web5 10.250.30.5:80 check fall 3 rise 2
server web6 10.250.30.6:80 check fall 3 rise 2
server web7 10.250.30.7:80 check fall 3 rise 2
server web8 10.250.30.8:80 check fall 3 rise 2
server web9 10.250.30.9:80 check fall 3 rise 2
server web10 10.250.30.10:80 check fall 3 rise 2
backend www-backend
# redirects to https below if http traffic is hitting the frontend
redirect scheme https if !{ ssl_fc } # redirects https
server web2 10.250.30.2:80 check fall 3 rise 2
bind :9000
stats hide-version
stats show-node
stats realm HAproxy-Statistics
stats uri /haproxy_stats
stats auth admin:**********
stats refresh 5s
You can only do it for HTTP, because in HTTPS, it is already to late (the certificate error is already there). Try this solution from chomps:
You’d put this in www-backend. However I have not tested this personally and I am not sure at this point if the redirect really considers the already rewritten host header. Try it.
