Http-request set-path not working
I am using haproxy version 2.0.6. Following are the relevant front and back ends:
frontend test
bind 127.0.0.1:1234
option http-buffer-request
acl receipt req.body -m reg data
use_backend receipt_back if receipt
default_backend prod
http-request set-path /app2/receipt.jsp <------------------
server SERVER-1 192.168.1.1:443 ssl verify none check
Everything is working fine but the line http-request set-path /app2/receipt.jsp is not working. The default URL is /app1/receipt.jsp and logs are showing that although the backend selected is receipt_back, the URL is still /app1/receipt.jsp
Output of haproxy -vv:
HA-Proxy version 2.0.6 2019/09/13 - https://haproxy.org/
TARGET = linux-generic
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -DTCP_USER_TIMEOUT=18
OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_THREAD=1 USE_OPENSSL=1 USE_ZLIB=1 USE_CPU_AFFINITY=1 USE_SYSTEMD=1
Feature list : -EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE -NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 -TPROXY -LINUX_TPROXY -LINUX_SPLICE -LIBCRYPT -CRYPT_H -VSYSCALL -GETADDRINFO +OPENSSL -LUA -FUTEX -ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY -TFO -NS -DL -RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER -PRCTL -THREAD_DUMP -EVPORTS
Built with multi-threading support (MAX_THREADS=64, default=64).
Built with OpenSSL version : LibreSSL 2.9.2
Running on OpenSSL version : LibreSSL 2.9.2
Built with transparent proxy support using: IP_TRANSPARENT IP_FREEBIND
Built with PCRE2 version : 10.32 2018-09-10
Total: 2 (2 usable), will use poll.
h2 : mode=HTTP side=FE mux=H2
: mode=HTX side=FE|BE mux=H1
: mode=TCP|HTTP side=FE|BE mux=PASS
Available services : none
Thank you very much.
Never mind. The issue is that by default HAProxy logs the request URI it receives from the client and not the request URI after set-path that is why the logs will always show the original req.uri. The above configuration works as intended. Thanks
