HTTP Strict Transport Security (HSTS) is showing as "Not Offered" for haproxy debug port 1974
We have added HTTP Strict Transport Security (HSTS) in our haproxy configuration, but the scan for haproxy debug port 1974 still shows as “Not Offered”. Below is the snippet of the haproxy configuration for the same. Can you please guide what needs to be done here to make the HSTS work properly.
frontend haproxy_frontend
bind *:1974 ssl crt /usr/local/etc/cert.crt
http-response set-header Strict-Transport-Security “max-age=31536000; includeSubDomains; preload”
default_backend haproxy_backend
server srv01 haproxyserver:1974 resolvers docker_app-net
http-response replace-header Location (.)(\b:1974/\b)(.)$ \1:“$HAPROXY_PORT”/\3
http-response replace-header Location (?i)(.)(\b"$APP_IP"/)(.) \1"$APP_IP":“$HAPROXY_PORT”/\3
stats uri /
stats auth “$debugUserName”:“$debugPass”
Haproxy sets a HTTP response header, that’s it.
Whether your client accepts and enables HSTS on a non-default port is up to your client.
