Http to https site with balancing
still not working sir… thanks for your time…
frontend localhost
default_backend nodes
stats hide-version
stats uri /stats
stats auth bunga:kamimasihmuda # Credentials for HAProxy Statistic report page.
backend nodes
option ssl-hello-chk
http-request set-header Host emos.enseval.com(disabled)
http-request set-header Host api.enseval.com(disabled)
http-send-name-header Host
server web01 emos.enseval.com:443 ssl verify none sni str(emos.enseval.com)
server web02 api.enseval.com:443 ssl verify none sni str(api.enseval.com)
if i use http-request set-header Host emos.enseval.com it work… but if i add http-request set-header Host api.enseval.com, emos.enseval will not work… only api.enseval.com will work…
thanks for your help sir… i appreciate it :slight_smile:
You did the opposite of what I just suggested.
Do not set any http-request set-header Host at all, instead put http-send-name-header Host into your backend configuration, that way, the Host header is set to the actual server name configured.
I did what u say sir…
I disabled
And just use
But both emos and api didn’t work…
If i just use
Only one will work…
I forgot, you also have to adjust the name of the server (http-send-name-header uses the internal server name in haproxy, not the hostname specified, so you need to replace web01 and web02):
backend nodes
 server emos.enseval.com emos.enseval.com:443 ssl verify none sni str(emos.enseval.com)
 server api.enseval.com api.enseval.com:443 ssl verify none sni str(api.enseval.com)
omg sir… its work like a charm…
this is what i want, you made my day sir… really thanks… many thanks sir…
god bless you…
finnally this work… i really apreciate your help sir… thanks a lot…
how happy iam … from asian with love… thanks sir… your my man
