Shame on me for not giving any background information.
That’s correct.
# dig consul.sre-test.sre.me
;; ANSWER SECTION:
consul.sre-test.sre.me. 2516 IN A 10.53.132.76
consul.sre-test.sre.me. 2516 IN A 10.53.132.78
consul.sre-test.sre.me. 2516 IN A 10.53.132.77
Seems like no other applications are using those ports, 443 and 8000:
lsof -n -i4TCP:8000 | grep LISTEN
consul 2991 root 12u IPv4 8899061 0t0 TCP 10.53.132.78:irdmi (LISTEN)
and
lsof -n -i4TCP:443 | grep LISTEN
haproxy 20929 root 8u IPv4 9339041 0t0 TCP *:https (LISTEN)
All I got is ERR_EMPTY_RESPONSE in browser. In terminal, although, sometimes I’m receive HTTP/1.1 301 Moved Permanently
#curl -v --cert wild.sre-test.sre.me https://consul.sre-test.sre.me
* About to connect() to consul.sre-test.sre.met port 443 (#0)
* Trying 10.53.132.78...
* Connected to consul.sre-test.sre.me (10.53.132.78) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* SSL connection using TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
* Server certificate:
* subject: CN=*.sre-test.sre.met,OU=TEST,OU=ETOOL,O=SBB,L=Melbourne,ST=Victoria,C=AU
* start date: Dec 13 13:39:01 2019 GMT
* expire date: Dec 12 13:39:01 2021 GMT
* common name: *.sre-test.sre.me
* issuer: CN=SBB Internal Issuing 2 CA 1,OU=PKI2,O=SBB,C=AU
> GET / HTTP/1.1
> User-Agent: curl/7.29.0
> Host: consul.sre-test.sre.me
> Accept: */*
< HTTP/1.1 301 Moved Permanently
< content-type: text/html; charset=utf-8
< location: /ui/
< date: Sat, 14 Dec 2019 22:18:24 GMT
< content-length: 39
<a href="/ui/">Moved Permanently</a>.
and sometimes curl: (52) Empty reply from server
# curl -v --cert wild.sre-test.sre.me https://consul.sre-test.sre.me
CApath: none
> GET / HTTP/1.1
> Accept: */*
* Empty reply from server
* Connection #0 to host consul.sre-test.oneadr.net left intact
Exchanging hdr_beg(host) for hdr(host) doesn’t change a thing.
A few lines from the log file:
Dec 14 22:54:58 is-srecore03t haproxy[20929]: 10.152.22.172:52522 [14/Dec/2019:22:54:58.282] httpfront httpfront/<NOSRV> 0/-1/-1/-1/0 301 112 - - LR-- 1/1/0/0/0 0/0 "GET / HTTP/1.1"
Dec 14 23:12:58 is-srecore03t haproxy[20929]: 10.53.132.78:54832 [14/Dec/2019:23:12:58.307] httpsfront~ consul/is-srecore03t 0/15/111 190 -- 1/1/0/0/0 0/0
Dec 14 23:18:16 is-srecore03t haproxy[20929]: 10.53.132.78:55030 [14/Dec/2019:23:18:16.835] httpsfront~ consul/is-srecore01t 0/5/100 190 -- 1/1/0/0/0 0/0
Dec 14 23:18:24 is-srecore03t haproxy[20929]: 10.53.132.78:55036 [14/Dec/2019:23:18:24.647] httpsfront~ consul/is-srecore02t 0/5/83 190 -- 1/1/0/0/0 0/0
And a little bit info about haproxy:
# haproxy -vv
HA-Proxy version 2.1.1 2019/12/11 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2021.
Known bugs: http://www.haproxy.org/bugs/bugs-2.1.1.html
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_PCRE=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
<default> : mode=HTTP side=FE|BE mux=H1
<default> : mode=TCP side=FE|BE mux=PASS
Available services :
prometheus-exporter
[FCGI] fcgi-app
