Hello friends,
I’ve some web applications running on tomcat. There are two identical application servers for each applications and I want a loadbalancer to distribute the network traffic between those two servers.
Therefore I have configured haproxy to act as a loadbalancer and redirect http (80) port to real ports defined in application servers. It worked pretty well so far.
Now I’ve installed ssl certificates to tomcat servers and decided to make people access through https instead of http.
I could not find out how to configure haproxy to listen port 443 (https), distribute the network traffic as a loadbalancer and redirect ports.
Below is my configuration designed for http.
I’ve tried to simple change port numbers, change mode from http to https or tcp… none of them worked or I’ve done something wrong or missed something…
Can you please tell me how I must modify this config?
Please note that I’ve already applied ssl certificates in tomcat so I do not need haproxy to apply ssl certificates.
Probably this is something very simple for most of you but this is the first time I use haproxy without any training.
daemondefaults
timeout server 50000listen arserver
bind :33000
use_backend srvs_arserverfrontend http
#default_backend defacl support base_reg ^.*support
acl smartit base_reg ^.*smartituse_backend srvs_support if support
use_backend srvs_smartit if smartitbackend srvs_support
balance source #roundrobin
hash-type consistent # optional
server BMCHELIXDWP1 10.19.0.110:80 check
server BMCHELIXDWP2 10.19.0.131:80 checkbackend srvs_smartit
server BMCHELIXDWP1 10.19.0.110:8080 check
server BMCHELIXDWP2 10.19.0.131:8080 checkbackend srvs_arserver
server BMCHELIXARS1 10.19.0.109:33000 check
server BMCHELIXARS2 10.19.0.111:33000 check
