Https to https://www
On my DNS provider I redirect http to https. It works well.
In the server, I use letsencrypt with a certificate over the domain with www and all requests with https and www work very well also.
My question is I want to add a redirection for requests from https://domain.com to https://www.domain.com.
I was searching quite a time in the forum with questions like this redirection-with-https/1693/3 and trying several configurations for the proxy but nothing works.
Can you please help me?
Many thanks in advance.
This is the content of haproxy.cfg
    maxconn 256
    lua-load /usr/local/etc/haproxy/acme-http01-webroot.lua
    chroot /jail
    ssl-default-bind-ciphers AES256+EECDH:AES256+EDH:!aNULL;
    timeout connect 5000ms
    timeout client 50000ms
    timeout server 50000ms
    stats uri /stats
frontend http
    acl url_acme_http01 path_beg /.well-known/acme-challenge/
    http-request use-service lua.acme-http01 if METH_GET url_acme_http01
frontend ft_ssl_vip
    bind *:443 ssl crt /usr/local/etc/haproxy/certs/ no-sslv3 no-tls-tickets no-tlsv10 no-tlsv11
    rspadd Strict-Transport-Security:\ max-age=15768000
    # www server redirect from subdomain [www]
    acl www_match_acl      hdr_end(host) -i www.mydomain.com
    use_backend apptest_server if www_match_acl
    server apptest_server XXX.XXX.XXX.XXX:XXXX check
Well, you don’t really have anything in your frontend currently that would actually redirect requests from https://domain.com to https://www.domain.com. Your current acl www_match_acl only checks if www.domain.com is already being used.
In order to have the redirect working I would replace your frontend config (starting with the acl) with this:
acl no_www_acl ssl_fc_sni -i domain.com
http-request redirect location https://www.domain.com%[capture.req.uri] code 302 if no_www_acl
use_backend apptest_server if !no_www_acl
So, if https://domain.com was requested, then redirect to https://www.domain.com (keeping any additional path or query string elements, if present). Send to apptest_server otherwise.
This config only works with browsers supporting SNI, but pretty much everything these days does. Alternatively you could write the acl like this (note the exact match):
acl no_www_acl hdr(host) -i domain.com
Thank you so much @kkoppel.
It didn’t work. I am certainly doing something wrong. I replaced acl section as you suggested and the resulting config (below) still does not work. Do you have any idea? Do I need to keep the acl www_match_acl so people connecting directly to www can access or with your snippet this is not necessary anymore?
Thank you so much again.
    maxconn 256
    chroot /jail
    stats uri /stats
frontend http
frontend ft_ssl_vip
The old acl www_match_acl is not needed anymore.
You should also make your haproxy log somewhere by adding something like this to the global section:
and these to the defaults section:
Then you should be able to see logs appearing in your syslog, provided it is configured to write local0 logs somewhere.
Could you describe what exactly happens when you try to access https://domain.com? Is the domain.com DNS name even resolving to the same IP as www.domain.com? :slight_smile:
Does accessing https://www.domain.com still work?
Hello kkoppel,
I realized I didn’t answer.
First of all thank you for your feedback, you pointed me in the right direction.
If this can help others, my problem was that I had a “URL redirection” in the DNS that permanently redirected @ to https://www.domain.com. Changing this for a A record instead that pointed to the hosting machine, and configuring the redirection with haproxy instead was the solution.
Thanks again kkoppel,
Best
