I was wondering what are the closest options to have something like iptables + ipset functionality in haproxy, and what the performance difference is. I have been looking a bit at this manual about dos protection[1].
Is the blacklisting with acl’s in files still the way to go with haproxy 2.2?
http-request deny if { src -f /etc/hapee-1.8/blacklist.acl }
I read some article that ipset had hardly any influence on the latency if it would contain ~50k entries. However you had to specify if you want a /24,/16 or individual ip set. Currently I have sets for rdp, web, smtp, pop/imap and ftp access, some have 60k entries.
From the example I see that I can list /23, /24 just in one file.
If specify in the file 1.1.4.0/24 and 1.1.4.1 will haproxy still process two lines or will 1.1.4.1 be disregarded?
Should this acl file be sorted? Or does it not matter how ip addresses are in the file, because haproxy optimizes this when loaded into memory?
How much memory would a list of ~50k entries use?
Is it better to just use one acl list for each service/frontend or is there next to no loss to use multiple, like this?
http-request deny if { src -f amazon-google.acl } || { src -f custom-blacklist.acl }
If I add an ip address to the acl via the admin socket[2], will this automatically be written to the acl file?
And a bit out of curiosity, how does blacklisting via acl’s compare to ipset in with added latency?
[1]
[2]
