Implementing Hitless Reloads within HAproxy in K8S
Hi
I have HAproxy implementation in Kubernetes
it is based on “haproxy:1.9” docker image.
I want to be able to update configuration without the need to restart pods.
I tried to follow “https://www.haproxy.com/blog/hitless-reloads-with-haproxy-howto/”
but the service fail to restart due to the following error :
“unknown stats parameter ‘socket’, expects ‘admin’, ‘uri’, ‘realm’, ‘auth’, ‘scope’, ‘enable’, ‘hide-version’, ‘show-node’, ‘show-desc’ or ‘show-legends’”
What am I missing ?
Are there any missing dependencies/utilities I need to include into the container in order to make it work ?
This is my haproxy.cfg:
    maxconn  4000
    log stdout  format raw  local0  debug
    maxconn  15000
    mode  http
    option  httplog
    option  dontlognull
    retries  3
    timeout  http-request 10s
    timeout  queue 1m
    timeout  connect 10s
    timeout  client 45s
    timeout  server 45s
    stats socket /var/run/haproxy.sock mode 600 expose-fd listeners level user
    stats hide-version
    stats scope .
  frontend chat_server_frontend
    default_backend web-backend
  backend web-backend
     server web1 172.17.0.18:8080 check
     server web2 172.17.0.16:8080 check
     server web3 172.17.0.19:8080 check
     stats refresh 1s
stats socket belongs into the global section, but you put it into the defaults section.
That worked however configuration changes are still not picked up :frowning:
  1. I ran the service
  2. tail the log
  3. removed backend server (server web3 172.17.0.19:8080 check) from the configuration (driven by configmap)
  4. pushed the change into K8S
  5. verified that the change is reflected inside the active pod
  6. haproxy still see the server i removed (can see it on the log )
any suggestion? what am I missing?
