In old version of haproxy 1.8 was
HTTP/1.1 302 Found
In new version 2.1 it is
HTTP/1.1 302 Found
with “l” in lowercase
Is it possible to revert it back to Uppercase “L”?
HTTP/1.1 302 Found
HTTP/1.1 302 Found
If you have a bogus client that breaks otherwise, yes, you can workaround this client bug with the bogus client features that have been introduced for this use-case. Something like:
h1-case-adjust location Location
default
h1-case-adjust-bogus-client
Also see h1-case-adjust and option h1-case-adjust-bogus-client.
Thank you! Works fine now.
