Large POST bodies to IIS (ASP.NET WebForms) require multi-MB tune.bufsize in HAProxy 3.2 to avoid HTTP.sys 400 errors
Title: IIS HTTP.sys 400 / Connection_Dropped errors with large POST bodies unless tune.bufsize increased (ASP.NET WebForms backend)
Hello everyone,
We are running HAProxy 3.2.13 (Debian package) in front of multiple IIS servers hosting a legacy ASP.NET WebForms application. We are seeing intermittent HTTP.sys errors (400 BadRequest / Connection_Dropped in httperr.log) when handling large POST requests (typically 700KB–3MB, sometimes up to ~5MB).
Environment:
  • HAProxy version: 3.2.13
  • Backend: IIS 10 / ASP.NET WebForms
  • Mode: HTTP
  • TLS terminated at HAProxy
  • Session persistence via cookie
  • Load balancing: leastconn
  • Requests contain large __VIEWSTATE and hidden form fields
  • Some pages include uploads up to ~5MB
Observed behavior:
With smaller tune.bufsize values (for example 32KB, 64KB, 512KB, 1MB, 2MB):
  • IIS logs show HTTP.sys 400 errors
  • httperr.log shows Connection_Dropped entries
  • HAProxy logs show failures on large POST requests
Increasing tune.bufsize resolves the issue.
Working configurations observed so far:
tune.bufsize 8388608
(8MB works)
tune.bufsize 16777216
(16MB also works)
However, increasing tune.bufsize to multi-MB values significantly increases memory usage and CPU cost per stream.
Example runtime stats during low traffic load with 8MB buffer size:
  • CurrConns ≈ 223
  • PoolAlloc_MB ≈ 665MB
  • Idle_pct ≈ 96%
So traffic load is low, but buffer allocation becomes large relative to connection volume.
Backend configuration currently used:
option http-buffer-request (Tried on and Off observer no difference unless the buffer size is set too high)
http-reuse safe
http-request del-header Transfer-Encoding if { req.hdr(Content-Length) -m found }
Profiling.tasks output shows most CPU time spent in:
  • process_stream
  • h1_io_cb
  • sc_conn_io_cb
Compression does not appear to be the primary contributor.
Additional reference behavior (comparison with FortiADC):
The same IIS backend servers operate correctly behind a FortiADC 200F appliance without requiring large proxy buffer sizes.
Observed behavior behind FortiADC:
  • Large POST bodies (~700KB to ~5MB) handled successfully
  • No HTTP.sys 400 / Connection_Dropped errors observed
  • No equivalent global multi-MB request buffer configuration required
Because the backend servers and application remain identical in both scenarios, this suggests the issue is related to request body forwarding behavior differences rather than application-level limits.
Question:
Is there a recommended approach for improving compatibility with IIS / HTTP.sys when forwarding multi-MB POST bodies without requiring large tune.bufsize values globally?
We would prefer a backend-level tuning approach if possible rather than increasing the global buffer size to several MB.
Any suggestions or known IIS interaction considerations would be appreciated.
