First of all I have to thank you for HAProxy. I also want to explain, that this is a crosspost - the other post is here (https://serverfault.com/questions/988721/require-a-http-authentication-only-for-connections-from-outside-my-lan-in-haprox ) but didn’t receive an answer yet so I thought I might ask in a community that is more specialised!
My frontend contains these lines to require a HTTP authentication
# Authentication
acl ValidOctoPrintUser http_auth(OctoPrintUsers)
http-request auth realm octoprint if !ValidOctoPrintUser
Now I want this authentication only for connections from outside of my LAN. Inside my LAN access should be granted without authentication.
I succeeded to do this for a single IP address like this:
# Authentication
# Exclude internal IPs from Authentication
acl InternalIP src -i 192.168.0.123
http-request auth realm octoprint if !InternalIP !ValidOctoPrintUser
However, I cannot achieve to do this for a range of IP addresses (like 192.168.0.[100-250] or a little less specific 192.168.0.*).
Can you point me a way to to this? Or is there even a better way to identify requests coming from inside my LAN?
Specify the subnetmask:
acl InternalIP src -i 192.168.0.0/24
This did indeed work!
Thank you @lukastribus .
Sorry for my lack of understanding, but what does the subnetmask do in this respect or why does it help to specify it? Maybe there is a link that explains it?
Sorry, I don’t know a lot about networks, but I want to learn!
It’s a bitmask, /24 or written in another way 255.255.255.0 indicates which part of the IP address belongs to the network as opposed to the host part.
For example:
10.0.0.0/24 indicates a network of total 256 addresses from 10.0.0.0 - 10.0.0.255.
10.0.0.0/16 indicates a network of total 65536 addresses from 10.0.0.0.0 - 10.0.255.255.
The ACL matching works exactly the same. By specifying a mask you are referring to an entire IP subnet.
Here some more theory about it:
A subnetwork or subnet is a logical subdivision of an IP network.:1,16 The practice of dividing a network into two or more networks is called subnetting.
Computers that belong to a subnet are addressed with an identical most-significant bit-group in their IP addresses. This results in the logical division of an IP address into two fields, the network number or routing prefix and the rest field or host identifier. The rest field is an identifier for a specific host or network interface.
The rout...
Classless Inter-Domain Routing (CIDR /ˈsaɪdər, ˈsɪ-/) is a method for allocating IP addresses and IP routing. The Internet Engineering Task Force introduced CIDR in 1993 to replace the previous addressing architecture of classful network design in the Internet. Its goal was to slow the growth of routing tables on routers across the Internet, and to help slow the rapid exhaustion of IPv4 addresses.
IP addresses are described as consisting of two groups of bits in the address: the most significant...
