Monitoring websockets with haproxy 2.2
Greetings - I’m working on upgrading haproxy from 1.8 to 2.2. I went through and corrected all of the warnings but I hit a snag with how we monitor websocket backends. Right now, we do this in the websocket specific backend:
option httpchk GET /ws?healthcheck=true HTTP/1.1\r\nHost:\ foobar.net\r\nConnection:\ Upgrade\r\nUpgrade:\ websocket\r\nSec-WebSocket-Key:\ x3JJHMbDL1EzLkh9GBhXDw==\r\nSec-WebSocket-Version:\ 13
http-check expect status 101
When I change it to the new way:
http-check send hdr Host foobar.net hdr Connection Upgrade hdr Upgrade websocket hdr Sec-WebSocket-Key x3JJHMbDL1EzLkh9GBhXDw== hdr Sec-WebSocket-Version 13
http-check send overwrites the Connection header and sets it to close (per the docs). Here are the headers my app receives when I use http-check send:
  host: 'foobar.net',
  upgrade: 'websocket',
  'sec-websocket-key': 'x3JJHMbDL1EzLkh9GBhXDw==',
  'sec-websocket-version': '13',
  'content-length': '0',
  connection: 'close'
This doesn’t work so I’ve had to revert back to the old deprecated way of doing this.
Is there any way to monitor websockets like we were doing with option httpchk? I’ve been reading through the docs, searching here and elsewhere, and I haven’t found anything. It doesn’t look like this is possible with 2.2 yet.
I just wanted to say that I experienced the same issue. I’ve therefore also needed to continue using the deprecated option httpchk configuration, published in this HAProxy blog post.
It would be best to file an issue on github, so we can keep track of this:
