Hi guys
I am new to this forum, i need advise what proper setup config for 4 cores 8gb RAM , which my goal is to utilize all resources of the vm spec. using nbthread, cpu map and max conn.
this is use for my application websites, this is the 1st entry before the webservers.
my config right now is:
maxconn 95k base on the fd limit set to haproxy is 200k
nbthread 4 - which base how many cpu cores
cpu-map auto: 1/1-4 0-3 - correct if im wrong , this config is for auto balance the workers in each processor
is this enough? or this is absolutely wrong. any best suggestion pls. thank you very much
