Need help to route https traffic on custom ports
Hi Team,
We would like to use haproxy ingress 1.7 on kubernetes to listen on 55560 port for https connection.
Could you please assist in this regard?
Here is my haproxy.cfg file. When trying to access, getting curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection error.
Https on 443 works fine.
# _version=5
# HAProxy Technologies
# https://www.haproxy.com/
# this file is not meant to be changed directly
# it is under haproxy ingress controller management
  localpeer local
  master-worker
  pidfile /var/run/haproxy.pid
  stats socket /var/run/haproxy-runtime-api.sock expose-fd listeners level admin
  stats timeout 1m
  ssl-default-bind-options no-sslv3 no-tls-tickets no-tlsv10
  ssl-default-bind-ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!3DES:!MD5:!PSK
  log stdout format raw daemon
  server-state-file global
  server-state-base /var/state/haproxy/
  log-format '%ci:%cp [%tr] %ft %b/%s %TR/%Tw/%Tc/%Tr/%Ta %ST %B %CC %CS %tsc %ac/%fc/%bc/%sc/%rc %sq/%bq %hr %hs "%HM %[var(txn.base)] %HV"'
  timeout http-request 5s
  timeout client 50s
  timeout queue 5s
  timeout server 50s
  timeout tunnel 1h
  timeout http-keep-alive 1m
peers localinstance
  peer local 127.0.0.1:10000
frontend healthz
  bind 0.0.0.0:1042 name v4
  bind :::1042 name v6 v4v6
  monitor-uri /healthz
  option dontlog-normal
frontend http
  bind 0.0.0.0:80 name v4
  bind :::80 name v6
  tcp-request connection expect-proxy layer4 if { src -f /etc/haproxy/maps/proxy-protocol-827c05ecc804eacf23a63899ca0ffcf6.map }
  http-request set-var(txn.base) base
  http-request set-var(txn.path) path
  http-request set-var(txn.host) req.hdr(Host),field(1,:),lower
  http-request set-var(txn.host_match) var(txn.host),map(/etc/haproxy/maps/host.map)
  http-request set-var(txn.host_match) var(txn.host),regsub(^[^.]*,,),map(/etc/haproxy/maps/host.map,'') if !{ var(txn.host_match) -m found }
  http-request set-var(txn.path_match) var(txn.host_match),concat(,txn.path,),map(/etc/haproxy/maps/path-exact.map)
  http-request set-var(txn.path_match) var(txn.host_match),concat(,txn.path,),map_beg(/etc/haproxy/maps/path-prefix.map) if !{ var(txn.path_match) -m found }
  use_backend %[var(txn.path_match),field(1,.)]
  default_backend default-default-ingress-default-backend-port-1
frontend https
  bind 127.0.0.1:443 name v4 accept-proxy
  bind ::1:443 name v6 v4v6 accept-proxy
frontend ssl
  bind 0.0.0.0:443 name v4
  bind :::443 name v6 v4v6
  log-format '%ci:%cp [%t] %ft %b/%s %Tw/%Tc/%Tt %B %ts %ac/%fc/%bc/%sc/%rc %sq/%bq %hr %hs haproxy.MAP_SNI: %[var(sess.sni)]'
  tcp-request content reject if !{ req_ssl_hello_type 1 }
  tcp-request inspect-delay 50000
  tcp-request content set-var(sess.sni) req_ssl_sni
  tcp-request content set-var(txn.sni_match) req_ssl_sni,map(/etc/haproxy/maps/sni.map)
  tcp-request content set-var(txn.sni_match) req_ssl_sni,regsub(^[^.]*,,),map(/etc/haproxy/maps/sni.map)
  use_backend %[var(txn.sni_match),field(1,.)]
  default_backend ssl
frontend stats
  bind *:1024
  bind :::1024 name v6
  stats uri /
  stats refresh 10s
frontend tcp-55560
  bind 0.0.0.0:55560 name v4
  bind :::55560 name v6 v4v6
  default_backend default-rapid-po-service-55560
backend default-ic-http-service-80
  default-server init-addr last,libc,none
  server SRV_1 xxxxxxxxxxx.com:80 check weight 128
  server SRV_1 xx.xxx.xx.xx:8080 check weight 128
  server SRV_2 127.0.0.1:8080 disabled check weight 128
  server SRV_3 127.0.0.1:8080 disabled check weight 128
  server SRV_4 127.0.0.1:8080 disabled check weight 128
  server SRV_5 127.0.0.1:8080 disabled check weight 128
  server SRV_6 127.0.0.1:8080 disabled check weight 128
  server SRV_7 127.0.0.1:8080 disabled check weight 128
  server SRV_8 127.0.0.1:8080 disabled check weight 128
  server SRV_9 127.0.0.1:8080 disabled check weight 128
  server SRV_10 127.0.0.1:8080 disabled check weight 128
  server SRV_11 127.0.0.1:8080 disabled check weight 128
  server SRV_12 127.0.0.1:8080 disabled check weight 128
  server SRV_13 127.0.0.1:8080 disabled check weight 128
  server SRV_14 127.0.0.1:8080 disabled check weight 128
  server SRV_15 127.0.0.1:8080 disabled check weight 128
  server SRV_16 127.0.0.1:8080 disabled check weight 128
  server SRV_17 127.0.0.1:8080 disabled check weight 128
  server SRV_18 127.0.0.1:8080 disabled check weight 128
  server SRV_19 127.0.0.1:8080 disabled check weight 128
  server SRV_20 127.0.0.1:8080 disabled check weight 128
  server SRV_21 127.0.0.1:8080 disabled check weight 128
  server SRV_22 127.0.0.1:8080 disabled check weight 128
  server SRV_23 127.0.0.1:8080 disabled check weight 128
  server SRV_24 127.0.0.1:8080 disabled check weight 128
  server SRV_25 127.0.0.1:8080 disabled check weight 128
  server SRV_26 127.0.0.1:8080 disabled check weight 128
  server SRV_27 127.0.0.1:8080 disabled check weight 128
  server SRV_28 127.0.0.1:8080 disabled check weight 128
  server SRV_29 127.0.0.1:8080 disabled check weight 128
  server SRV_30 127.0.0.1:8080 disabled check weight 128
  server SRV_31 127.0.0.1:8080 disabled check weight 128
  server SRV_32 127.0.0.1:8080 disabled check weight 128
  server SRV_33 127.0.0.1:8080 disabled check weight 128
  server SRV_34 127.0.0.1:8080 disabled check weight 128
  server SRV_35 127.0.0.1:8080 disabled check weight 128
  server SRV_36 127.0.0.1:8080 disabled check weight 128
  server SRV_37 127.0.0.1:8080 disabled check weight 128
  server SRV_38 127.0.0.1:8080 disabled check weight 128
  server SRV_39 127.0.0.1:8080 disabled check weight 128
  server SRV_40 127.0.0.1:8080 disabled check weight 128
  server SRV_41 127.0.0.1:8080 disabled check weight 128
  server SRV_42 127.0.0.1:8080 disabled check weight 128
  server SRV_1 xxxxxxx:55560 check weight 128
backend default-rapid-service-44448
  server SRV_1 xxxxxxxxxx:44448 check weight 128
backend default-sample-http-service-80
  server SRV_1 xxxxxxxxxxxx:80 check weight 128
backend default-sample-https-service-443
  server SRV_1 xxxxxxxxxxxx:443 check weight 128
backend ssl
  server https 127.0.0.1:443 send-proxy-v2
Regards,
Kalyan
Hey,
you are stating, that you want HAproxy to listen on port 44444, but in the config you posted, I can not find that port anywhere.
I guess you either forgot to include this bit of configuration in your post, or, as something seems to respond on port 44444, that another process is maybe listening on this port?
I have updated the port, could you please suggest
Hmm, okay.
As far as I see in your config, you are using the TCP mode to just forward packets, but don’t actually terminate SSL on HAProxy, but pipe it through to kubernetes and terminate there.
Is your SRV_1 backend server expecting HTTPs-Traffiv on Port 55560?
From what I have seen on Google, this error could indicate, that you try speaking using HTTPs on a HTTP-connection.
Could that be the case here too?
Thanks for the reply.
I am expecting https traffic on port 55560. Could you please suggest how to use custom port for https traffic on haproxy-ingress.
Regards,
Kalyan
