No timestamps for ALERT, WARNING
Hi
This question is regarding logging.
When haproxy emits “ALERT” or “WARNING” to the log, there are no timestamps. This makes life more difficult when filters (e.g. grep) are used to find such events and isolate the time of the problem.
Is it possible to configure haproxy in a way that it will add timestamps to such events?
Example:
# cat access.log | egrep 'ALERT' | head -1
[ALERT] 039/120255 (1115) : backend 'ServerFarm' has no server available!
We are using haproxy 2.2.8. on CentOS 7:
# haproxy -vv
HA-Proxy version 2.2.8-7bf78d7 2021/01/13 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.2.8.html
Running on: Linux 3.10.0-1160.11.1.el7.x86_64 #1 SMP Fri Dec 18 16:34:56 UTC 2020 x86_64
  TARGET  = linux-glibc
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
  OPTIONS = USE_PCRE=1 USE_PCRE_JIT=1 USE_THREAD=1 USE_PTHREAD_PSHARED=1 USE_LINUX_TPROXY=1 USE_LIBCRYPT=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1 USE_TFO=1 USE_NS=1 USE_SYSTEMD=1
  DEBUG   =
Feature list : +EPOLL -KQUEUE +NETFILTER +PCRE +PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD +PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -CLOSEFROM +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with OpenSSL version : OpenSSL 1.0.2k-fips  26 Jan 2017
Running on OpenSSL version : OpenSSL 1.0.2k-fips  26 Jan 2017
Built with gcc compiler version 4.8.5 20150623 (Red Hat 4.8.5-44)
            fcgi : mode=HTTP       side=BE        mux=FCGI
       <default> : mode=HTTP       side=FE|BE     mux=H1
              h2 : mode=HTTP       side=FE|BE     mux=H2
       <default> : mode=TCP        side=FE|BE     mux=PASS
        [FCGI] fcgi-app
Many thanks
Toni
I do not think this is currently possible, no.
I suggest you file a feature request at github:
Submitted feature request here:
