Nodejs express web backend behind haproxy
I am trying to set up a backend with nodejs and haproxy. The problem is that, when using haproxy, when you access a page, it loads, but sometimes other resources (js, css, etc) will not load (Err: Connection refused in Chrome, failed to load … in firefox)
It seems that adding option http-server-close in haproxy configuration file solves the problem, but why is this happening? As far as I am aware, nodejs supports keepalive and enqueues requests. What am I missing?
Thanks.
I asked this on stackoverflow here.
It’s impossibile to tell with the informations provided.
Share the entire configuration, the output of haproxy -vv as well as the log output of haproxy during this problem.
Of course, sorry about that, I was on a hurry.
Configuration file is:
option http-server-close # THIS LINE fixes the problem
frontend not-secure-in
http-request redirect scheme https if { ssl_fc,not }
frontend secure-in
bind *:8000 ssl crt /etc/haproxy/certs/
use_backend aa if { req.hdr(host) -i xxx.xxx.xxx }
default_backend bb
backend bb
server server_bb localhost:9000
backend aa
server server_aa 192.168.1.201:8000
The one that gives me trouble is server_aa, which is a full webpage. Server_bb is a RESTAPI.
I have commented the line that apparently solves this, but why?
$ haproxy -vv
HA-Proxy version 1.8.8-1ubuntu0.10 2020/04/03
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fdebug-prefix-map=/build/haproxy-Lb4xC1/haproxy-1.8.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_GETADDRINFO=1 USE_ZLIB=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1 USE_PCRE_JIT=1 USE_NS=1
Thanks.
anyone?
Most likely a buggy backend server, or, possibly a bug in haproxy.
Capture the haproxy - backend server traffic in working and non-working situation and analyze it.
