We have two configurations using haproxy:
- Production: With SSL cert on AWS NLB. Haproxy binds to port 80. Logging is working fine, for example:
Jul 14 09:41:04 localhost haproxy[996]: 210.200.69.57:42375 [14/Jul/2021:09:41:04.423] node_gateway api_gateway/ccpsa1 80/0/1/204/285 201 604 - - ---- 4/4/0/1/0 0/0 "POST /capi/v2/users/_get_invoice HTTP/1.1"
- Staging: Using letsencrypt cert with haproxy bound to port 443. See below. This configuration logs service starts and stops, but connections don’t get logged. Any idea what I am doing wrong?
cat /etc/haproxy/haproxy.cfg
log 127.0.0.1:514 local0
#log /dev/log local1 notice
maxconn 2048
#option dontlognull
frontend apisslproxy
bind :443 ssl crt /etc/haproxy/redacted.com.pem
acl PATH_settcon path_beg -i /console/settlement
acl PATH_assets path_beg -i /assets
acl PATH_settlement path_beg -i /settlement
acl PATH_hc path_beg -i /health_check
acl PATH_metrics path_beg -i /metrics
use_backend settcon if PATH_settcon || PATH_assets || PATH_settlement || PATH_hc || PATH_metrics
acl PATH_kyc path_beg -i /kyc
use_backend kyc if PATH_kyc
default_backend api_gateway
frontend www-http
bind :80
http-request silent-drop if TRUE
