I have an Exchange 2013 on prem environment with haproxy doing the load balancing.
When connecting via Outlook to Exchange via the LB/Haproxy, I’m constantly prompted for passwords despite entering the correct password and seeing all 401/200 logs and no 403 errors on neither the CAS or the LB logs.
When I force Outlook (via DNS) to connect to the Exchange server directly, the errors go away, so clearly the error is somewhere in the HAPROXY config. Can anyone review and advise?
log 127.0.0.1 local0 notice
stats socket /var/run/haproxy.sock mode 600 expose-fd listeners level user
maxconn 4096
maxcompcpuusage 100
maxcomprate 0
nbproc 1
ssl-server-verify required
log 127.0.0.1 local0 info
no option httpclose
no option http-server-close
timeout server 15m
timeout client 15m
timeout check 10s
#timeout http-keep-alive 10s
#timeout check 10s
maxconn 4096
frontend fe_e13_o
bind [internalIP:443] ssl crt /loc/of/cert/cert.pem
use_backend be_e13_o
backend be_e13_o
source [internalIP]
server exchangeA [serverIP]:443 check ssl inter 15s verify required ca-file /etc/ssl/certs/ca-bundle.crt
