Hi!
I’ve got a weird problem with haproxy peering. Everything is working fine, haproxy instances are syncing stick tables between them correctly up until some point where it stops completely and the proto_err
counter starts to go up. There’s not a single error pushed to the logs. Is there a way to get any logs about what’s going on with the haproxy peering?
Here’s partial output from the peers state:
0x55939dff3380: [12/Dec/2020:09:24:58] id=mypeers state=0 flags=0x3 resync_timeout=22d7h task_calls=1093943
0x55939dff92f0: id=haproxy-1(remote) addr=X:1024 status=ESTA reconnect=4s confirm=0 tx_hbt=773183 rx_hbt=771493 no_hbt=18 new_conn=10136 proto_err=4395
flags=0x20000000 appctx:0x7ffb4801fea0 st0=7 st1=0 task_calls=2186 state=EST
last_local_table:0x55939e007260 id=jitsi-meet local_id=1 remote_id=1
shared tables:
0x55939e007260 local_id=1 remote_id=1 flags=0x0 remote_data=0x80001
last_acked=0 last_pushed=46352 last_get=0 teaching_origin=46269 update=46352
table:0x55939dffcc20 id=jitsi-meet update=46352 localupdate=46352 commitupdate=46352 syncing=0
