Possible bug with the prometheus exporter in HAProxy 2.0.1
I have recently installed a HAProxy 2.0.1, but have been experiencing a strange problem where the CPU is maxed out after a little while.
I have tracked the problem down to the build-in prometheus exporter that doesn’t close the connection properly leaving it in CLOSE_WAIT after each hit to /metrics.
After a while it runs out of connections, stops serving requests and maxes out the CPU.
Here is my “stats” config:
frontend stats
    bind *:8404
    option http-use-htx
    stats uri /stats
    stats refresh 10s
haproxy -vv:
HA-Proxy version 2.0.1-1ppa1~bionic 2019/06/27 - https://haproxy.org/
Build options :        [0/137]
TARGET  = linux-glibc
CPU     = generic
CC      = gcc
CFLAGS  = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-O7_wB6/haproxy-2.0.1=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
-fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wn
o-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wtype-limits -Wshift-negative-value -Wshift-overflow
=2 -Wduplicated-cond -Wnull-dereference
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +REGPARM -STATIC_PCRE -STATI
C_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT
-DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with OpenSSL version : OpenSSL 1.1.1  11 Sep 2018
Running on OpenSSL version : OpenSSL 1.1.1  11 Sep 2018
Built with PCRE2 version : 10.31 2018-02-12
Available services :
        prometheus-exporter
There are tons of bugs in 2.0.1 that are fixed in the git-tree. I suggest you either wait for 2.0.2 or compile haproxy yourself from the 2.0 git tree or the current snapshot tarballs.
edit: the prometheus issue specifically was also fixed:
