Prolem with separate logging
Hi guys!
I have a little problem with logging. I tried to follow this( Introduction to HAProxy Logging - HAProxy Technologies ) article to set up separate logging on my instance but i have a problem. I can seprate the traffic and admin logs but in addition every logs go to syslog as well.
My haproxy config:
        log 127.0.0.1:514 local0
        stats socket ipv4@127.0.0.1:9999 level admin
        stats timeout 5m
rsyslog config:
# Create an additional socket in haproxy's chroot in order to allow logging via
# /dev/log to chroot'ed HAProxy processes
$ModLoad imuxsock
$AddUnixListenSocket /var/lib/haproxy/dev/log
# Send HAProxy messages to a dedicated logfile
#if $programname startswith 'haproxy' then /var/log/haproxy.log
# Collect log with UDP
$ModLoad imudp
$UDPServerAddress 127.0.0.1
$UDPServerRun 514
# Creating separate log files based on the severity
local0.* /var/log/haproxy/haproxy-traffic.log
local0.notice /var/log/haproxy/haproxy-admin.log
If you have any ideas, i welcome you.
Maybe you need to add a line with stop at the end?
local0.* stop
we use a pretty close config. At the end of our syslog config we have this line :
& stop
With this, logs should not be sent to syslog after being processed
