MBA
1
Hello Team
We have a inhouse developed application which works on Port 5000 TCP
Our application has an interface which shows IP Address of a client when someone logs in, our requirement is to preserve the Client IP Address
We have configured HA Proxy as a load balancer/reverse proxy but we encountered following issues:
It never passes client IP Address to our application only load balancer IP Address is shown
Whenever we try accept-proxy variable we don’t see any request at application
We have tried numerous solutions shared over the internet but nothing works
Do we need to any proxy protocol implementation in our application?
Can anyone please assist or put us in direction?
Hi!
You have to set the send-proxy parameter of the server line in your HAProxy backend: HAProxy version 2.4.15 - Configuration Manual
and yes, your application must support parsing the proxy protocol, cause it is inserted at the beginning of the first TCP payload.
MBA
3
Hi Baptiste
Thanks for the guidance, here is the configuration file:
Global settings
log 127.0.0.1:514 local0
pidfile /var/run/haproxy.pid
maxconn 4000
user root
group root
# turn on stats unix socket
Defaults block
timeout if backends do not reply
timeout connect 5000ms
timeout on client side
timeout client 50000ms
timeout on server side
timeout server 50000ms
Front End block for Stats
frontend stats
bind 0.0.0.0:85
option logasap
option forwardfor header X-Client
stats auth admin:admin
stats uri /stats
stats refresh 5s
Front End block
frontend front
bind 172.16.35.83:5001 transparent
option logasap
default_backend back
Backend End block
backend back
option tcp-check
server tcp01 server_IP:5000 send-proxy
####Config End
MBA
4
@Baptiste Can you please refer to documentation for implementation in application?
