Question on haproxy 1.8.3
Hi All,
I have one question related to same with haproxy 1.8.3 version
Can I do ACL at front end or backend check if its http2, send to grpc backend, else forward to nginx??
Configuration
frontend https-in
HTTP/2 - see https://www.haproxy.com/blog/whats-new-haproxy-1-8/
h2 is HTTP2 with TLS - see https://http2.github.io/faq/
Order matters, so h2 before http1.1
bind *:443 ssl ca-file /f0/base/haproxy/ca.pem  crt /f0/base/haproxy/server.pem alpn h2,http/1.1
#option httpclose
#option forwardfor
use_backend nodes-http2 if { ssl_fc_alpn -i h2 }
default_backend nodes-http
backend nodes-http
http-response set-header Strict-Transport-Security "max-age=16000000; includeSubDomains; preload;"
server node1 0.0.0.0:4443 check send-proxy
#This way browsers which do support HTTP/2 are still able to connect to our website
backend nodes-http2
# HSTS (15768000 seconds = 6 months)
http-response set-header Strict-Transport-Security max-age=15768000
# path: /helloworld.Greeter/SayHello
# path: /package.servicename/methodname
#use-server grpcServer if { req.hdr(Content-Type) -i application/grpc }
#use-server grpcServer if { path_beg -i /gnmi }
use-server grpcServer if { url_sub  -i <grpc> }
#use-server grpcServer if { path_sub grpcserver }
server grpcServer localhost:6666 weight 0
# all the rest is forwarded to this server
server default localhost:4443 check
haproxy -f /f0/base/haproxy/haproxy.grpc.cfg -d
select : pref=150, test result FAILED
Total: 2 (1 usable), will use poll.
Using poll() as the polling mechanism.
00000000:https-in.accept(0003)=0004 from [192.168.1.1:48291] ALPN=h2
00000000:https-in.clireq[0004:ffffffff]: POST /gnmi.gNMI/Capabilities HTTP/1.1
00000000:https-in.clihdr[0004:ffffffff]: password: PA$$WORD
00000000:https-in.clihdr[0004:ffffffff]: routerid:
00000000:https-in.clihdr[0004:ffffffff]: username: TestUser
00000000:https-in.clihdr[0004:ffffffff]: grpc-encoding: identity
00000000:https-in.clihdr[0004:ffffffff]: grpc-accept-encoding: identity,deflate,gzip
00000000:https-in.clihdr[0004:ffffffff]: te: trailers
00000000:https-in.clihdr[0004:ffffffff]: content-type: application/grpc
00000000:https-in.clihdr[0004:ffffffff]: user-agent: grpc-c++/1.1.0-dev grpc-c/2.0.0-dev (linux; chttp2; good)
00000000:https-in.clihdr[0004:ffffffff]: host: localhost
00000000:nodes-http2.srvcls[0004:adfd]
00000000:nodes-http2.clicls[0004:adfd]
00000000:nodes-http2.closed[0004:adfd]
00000001:https-in.accept(0003)=0004 from [192.168.1.1:48293] ALPN=h2
00000001:https-in.clireq[0004:ffffffff]: POST /gnmi.gNMI/Subscribe HTTP/1.1
00000001:https-in.clihdr[0004:ffffffff]: filter: FAN
00000001:https-in.clihdr[0004:ffffffff]: password: PA$$WORD
00000001:https-in.clihdr[0004:ffffffff]: routerid:
00000001:https-in.clihdr[0004:ffffffff]: username: TestUser
00000001:https-in.clihdr[0004:ffffffff]: grpc-encoding: identity
00000001:https-in.clihdr[0004:ffffffff]: grpc-accept-encoding: identity,deflate,gzip
00000001:https-in.clihdr[0004:ffffffff]: te: trailers
00000001:https-in.clihdr[0004:ffffffff]: content-type: application/grpc
00000001:https-in.clihdr[0004:ffffffff]: user-agent: grpc-c++/1.1.0-dev grpc-c/2.0.0-dev (linux; chttp2; good)
00000001:https-in.clihdr[0004:ffffffff]: grpc-timeout: 24H
00000001:https-in.clihdr[0004:ffffffff]: host: localhost
00000001:nodes-http2.srvcls[0004:adfd]
00000001:nodes-http2.clicls[0004:adfd]
00000001:nodes-http2.closed[0004:adfd]
netstat -an | grep -i 6666
tcp 0 0 ::ffff:127.0.0.1:6666 :::* LISTEN
tcp 0 0 ::ffff:127.0.0.1:6666 ::ffff:127.0.0.1:33635 TIME_WAIT
Can you please give me pointers on how to fix this?
Thanks,
Your configuration is way too complicated and confusing. Please avoid using the use-server keyword, this will only be very confusing and you will end up with a mess of a configuration.
You seem to want to route traffic to the 6666 backend only when the protocol is H2 AND the url contains (both conditions need to be true).
So instead of the confusion in your backend with use-server and a server with weight 0:
  • declare a backend for a single purpose
  • do all the routing decisions in your frontend
So:
 #option httpclose
 #option forwardfor
 use_backend nodes-http2 if { ssl_fc_alpn -i h2 } { url_sub  -i <grpc> }
backend nodes-http
backend nodes-http2
This will also make your logs and debugs readable. In your current configuration you will have a hard time troubleshooting this.
Grazie Luka.
But I had to remove “mode http” from nodes-http2:
So as below: this made it work
frontend https-in
log /tmp/haproxy.log local0 debug
use_backend nodes-http2 if { ssl_fc_alpn -i h2 } { url_sub -i }
backend nodes-http
#http-response set-header Strict-Transport-Security "max-age=16000000; includeSubDomains; preload;"
backend nodes-http2
Thanks again.
