RDP session via RD Gateway behind Haproxy stuck
Dear Friends, i use Debian 12 Bookworm and Haproxy for loadbalance traffic between gateways. if all backend servers working without problem, but if simulate failover when put down on of backend servers active RDP session deadly freeze and unable to close, only if kill rdp client process.
if stop haproxy process and start again active session reconnects without problem, if not window still stucked until killing process. i trying to change option httpclose, set on-marked-down for backend servers and a lot of config changes without success. Please help solving this issue!
config example:
        log /dev/log    local0
        log /dev/log    local1 notice
    ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:@SECLEVEL=0
    ssl-default-server-options ssl-min-ver TLSv1.0 no-tls-tickets
   # ssl-dh-param-file etc/haproxy/dhparam.pem
    log stdout format raw local0
        log     global
        mode    http
        option  httplog
        option  dontlognull
        option  redispatch
        #option h1-case-adjust-bogus-client
        option httpclose
        #no option http-use-htx
        timeout client  30s
        timeout client-fin 30s
        timeout server  35s
        timeout tunnel        3600s
        timeout http-keep-alive  15s
        timeout http-request    30s
frontend rds_gateway_front
 bind *:443 ssl crt /etc/haproxy/pki/contoso.com.pem no-tls-tickets alpn http/1.1 allow-0rtt
 option http-no-delay
# option http-server-close # Connection to gw Not work with this option
# Internet Explorer and NTLM with HTTPS sites
 option http-use-proxy-header
 #option accept-invalid-http-request
 #no option  http-buffer-request
 #http-reuse always
 #Dump all headers
 http-request capture req.hdrs len 1024
 default_backend rds_gateway
backend rds_gateway
 #HTTPS
 #default-server ssl tfo verify none alpn http/1.1 check stick allow-0rtt
 #HTTP
 default-server alpn http/1.1 check on-marked-down shutdown-sessions
 dynamic-cookie-key  RDGW
 cookie RDGW insert indirect nocache
 stick-table    type ip size 5000
 stick on       src
# no option redispatch
# no option persist
 option prefer-last-server
 option httpchk GET /
 http-check expect status 200
 http-request add-header X-Forwarded-For %[src]
 http-request set-header X-Forwarded-Host %[req.hdr(host)]
 http-request set-header X-Client-IP %[src]
 http-request set-header X-Client-IP req.hdr_ip([X-Forwarded-For])
server RDGW1 10.20.10.71:80
server RDGW2 10.20.10.72:80
#server RDGW2 10.20.10.72:443 ssl verify none alpn h2,http/1.1 check
#server RDGW1 10.20.10.72:443 ssl verify none check cookie RDGW1 weight 50
listen statistics
bind *:9001
stats refresh 30s
stats show-node
stats show-legends
stats show-desc desc
stats auth letme:in
stats uri /stats
stats hide-version
