Redirecting to certain servers faills
i want to set up a reverse proxy to redirect calls on my dynamic dns depending on the path. So if it is “mydyndns.com/web1” it should redirect to server “web1” and so on. I have set three ACL, based on path_beg. But whenever I enter any of the mentioned paths like “mydyndns.com/portainer” on the web browser, I always get redirected to default_backend (whatever I set it to).
Any ideas how to solve this?
    maxconn 300
    log     global
    mode    http
    option  httplog
    option  dontlognull
    timeout client  50000
    timeout server  50000
frontend http-in
    acl has_portainer path_sub -i /portainer/#/auth
    acl has_grafana path_sub /grafana/
    acl has_influx  path_sub /write/
    use_backend grafana_backend if has_grafana
    use_backend portainer_backend if has_portainer
    use_backend influxdb_backend if has_influx
    default_backend grafana_backend
    server grafana_test 192.168.0.3:3000 check
    server portainer 192.168.0.3:9000 check
   server influxdb 192.168.0.3:8086 check
EDIT:
I work with docker for all components
This ACL is wrong. the ‘#’ character in HTML is an anchor, some kind of a pointer in your HTML code that your browser uses to move to this part of the page. Modern apps use it to modify the display part only.
Just give a try to this ACL: acl has_portainer path_sub -i /portainer
Note that I would not use path_sub, but path_beg instead since your matching is at the BEGinning of the path.
thanks for the reply!
I tried changing to acl has_portainer path_beg -i /portainer but there is no visible effect. I always get redirected to the default backend.
Does it have to do with my docker setup? Do I have to define the backend server with the “docker ip” or with regular local IP that I use from within my local network?
