Reverse HAProxy
Hello
I have IIS web Site in VM 192.168.2.10 , in this machine i have 2 sites www.site1.com and www.site2.com
i have 1 WAN 80.80.80.80 both site host in this WAN ip
so i want to make configuration
if someone types from outside : wwww.site1.com wnat to open site1 web page
is someone types www.site2.com wants to open site2 web page
both are in same Vm machine
i want to make ssl for site 1 and site 2 as well
,i am not guru in this direction and need advice
please see my sample config, but not workings :
maxconn 10000
stats socket /tmp/haproxy.socket level admin
uid 80
gid 80
nbproc 1
hard-stop-after 15m
chroot /tmp/haproxy_chroot
frontend shared-merged
bind 80.80.80.80:443 name 80.80.80.80:443 ssl crt-list /var/etc/haproxy/shared.crt_list - here is all cert path for both site
acl https ssl_fc
timeout client 30000
acl ACL1 var(txn.txnhost) -m str -i site1.com
acl aclcrt_www.site1.com var(txn.txnhost) -m reg -i ^haproxy-pfsense(:([0-9]){1,5})?$
acl ACL1 var(txn.txnhost) -m str -i www.site2.com
use_backend www.site1.com_ipvANY if ACL1 aclcrt_site1
use_backend www.site2.com_ipvANY if ACL1
frontend http-to-https
bind 80.80.80.80:80 name 80.80.80.80:80
http-request redirect scheme https
backend www.site1_ipvANY
id 100
timeout connect 30000
timeout server 30000
server www.site1.com 192.168.2.5:80 id 101
id 102
server www.site2.com 192.168.2.5:80 id 101 check-ssl verify none
i tried but can not figure out
can you tell us why you enabled SSL check on port 80 in backend site2?
You don’t have any health check enabled on your backend server line. I would enable them first and check the server status in haproxy stats page.
Then, you don’t need all these acls in your frontend. I don’t even understand what you need to do.
From my point of view, since your server already handle virtualhosting, just have one frontend, one backend and done. then you can add more complexity if needed.
