I’m trying to setup an internal proxy that forward HTTP requests to a HTTPS backend.
An echo server https://echo-5ooike70s.now.sh was used for development. I’ve managed to setup the configuration following previous discussion here, but the following configuration:
maxconn 3000
timeout server 10s
timeout client 10s
frontend frontend_http
bind *:8000
default_backend backend_https
server remote echo-5ooike70s.now.sh:443 check ssl verify none
Results in errors:
[WARNING] 092/134701 (46341) : Server backend_https/remote is DOWN, reason: Layer6 invalid response, info: "SSL handshake failure", check duration: 13ms. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[ALERT] 092/134701 (46341) : backend 'backend_https' has no server available!
HA-Proxy version 1.9.4 2019/02/06
curl -vvk results for the server are shown here https://gist.github.com/hden/7cc26dc03d755e47645fd667e48e87ca#file-curl-vvk
Any help or suggestions are appreciated. Thanks!
