I have been running HA-Proxy version 1.7.5-2 2017/05/27 from the raspbian repo for several months without issue.
I’d like to now run a more up to date version on Centos for ARM so I’ve compiled both 1.9.0 and 2.0-dev4 on a fresh raspberry pi with CentOS 7 installed. However for both versions i get an immediate segmentation fault.
I dont really know what I’m doing with gdb but I tried running it with gdb and this is the output below; can anyone give me any insights as to what may be happening here?
TIA.
John.
# gdb /usr/local/sbin/haproxy
GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-114.el7
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "armv7hl-redhat-linux-gnueabi".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /usr/local/sbin/haproxy...done.
(gdb) set pagination 0
(gdb) run -f /etc/haproxy/haproxy.cfg -d
Starting program: /usr/local/sbin/haproxy -f /etc/haproxy/haproxy.cfg -d
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/libthread_db.so.1".
warning: Probes-based dynamic linker interface failed.
Reverting to original interface.
Cannot access memory at address 0xc2400000
Missing separate debuginfos, use: debuginfo-install bzip2-libs-1.0.6-13.el7.armv7hl elfutils-libelf-0.172-2.el7.armv7hl elfutils-libs-0.172-2.el7.armv7hl glibc-2.17-260.el7_6.5.armv7hl keyutils-libs-1.5.8-3.el7.armv7hl krb5-libs-1.15.1-37.el7_6.armv7hl libattr-2.4.46-13.el7.armv7hl libcap-2.22-9.el7.armv7hl libcom_err-1.42.9-13.el7.armv7hl libgcc-4.8.5-36.el7_6.2.armv7hl libgcrypt-1.5.3-14.el7.armv7hl libgpg-error-1.12-3.el7.armv7hl libselinux-2.5-14.1.el7.armv7hl lz4-1.7.5-2.el7.armv7hl nss-softokn-freebl-3.36.0-5.el7_5.armv7hl openssl-libs-1.0.2k-16.el7_6.1.armv7hl pcre-8.32-17.el7.armv7hl systemd-libs-219-62.el7_6.6.armv7hl xz-libs-5.2.2-1.el7.armv7hl zlib-1.2.7-18.el7.armv7hl
(gdb) bt
#0 0x76fe46f4 in dl_open_worker () from /lib/ld-linux-armhf.so.3
#1 0x76fdf970 in _dl_catch_error () from /lib/ld-linux-armhf.so.3
#2 0x76fe3c68 in _dl_open () from /lib/ld-linux-armhf.so.3
#3 0x76b6c9c8 in do_dlopen () from /lib/libc.so.6
#4 0x76fdf970 in _dl_catch_error () from /lib/ld-linux-armhf.so.3
#5 0x76b6cad4 in __libc_dlopen_mode () from /lib/libc.so.6
#6 0x76b401a4 in nss_load_library () from /lib/libc.so.6
#7 0x76b40d38 in __nss_lookup_function () from /lib/libc.so.6
#8 0x76b40e90 in __nss_lookup () from /lib/libc.so.6
#9 0x76aee4dc in getpwnam_r@@GLIBC_2.4 () from /lib/libc.so.6
#10 0x76aedc14 in getpwnam () from /lib/libc.so.6
#11 0x00146d78 in cfg_parse_global (file=0x2c7178 "/etc/haproxy/haproxy.cfg", linenum=7, args=0x7efff02c, kwm=<optimized out>) at src/cfgparse-global.c:475
#12 0x000dd7f4 in readcfgfile (file=0x2a9528 "/etc/haproxy/haproxy.cfg") at src/cfgparse.c:2147
#13 0x000d6e64 in init (argc=<optimized out>, argc@entry=4, argv=<optimized out>, argv@entry=0x76a556b0) at src/haproxy.c:1649
#14 0x0002bc90 in main (argc=4, argv=0x76a556b0) at src/haproxy.c:2683
Can you provide the output of haproxy -vv (unless that crashes also)?
here you go:
# /usr/local/sbin/haproxy -vv
HA-Proxy version 2.0-dev4 2019/05/22 - https://haproxy.org/
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_PCRE=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1 USE_TFO=1 USE_NS=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL -GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with multi-threading support (MAX_THREADS=32, default=4).
h2 : mode=HTTP side=FE mux=H2
<default> : mode=HTX side=FE|BE mux=H1
<default> : mode=TCP|HTTP side=FE|BE mux=PASS
Available services : none
Can you try without the user and group directives in the configuration (keep using root)?
Running as root and no user/group in the cofig I still get a Segmentation Fault but there’s a diffferent output from gdb:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x75e5bbf0 (LWP 1001)]
fd_rm_from_fd_list (list=0x2997d8 <update_list>, fd=fd@entry=8, off=off@entry=24) at src/fd.c:275
275 unlikely(!_HA_ATOMIC_DWCAS(((void **)(void *)&_GET_NEXT(fd, off)), ((void **)(void *)&cur_list), (*(void **)(void *)&next_list))))
I’m investigating, it’s about threading.
Workaround for now is to disable threading by adding nbthread 1 to your global section.
jszjsmith:
You probably meant 1.9.8 because the bug was only introduced in that release (1.9.7 and older work fine).
I’ve filed a bug:
opened 10:19PM - 23 May 19 UTC
closed 06:00PM - 27 May 19 UTC
type: bug
severity: medium
status: fixed
subsystem: core
John Smith reported on discourse that haproxy 1.9 and dev crashes on Raspberry P… i's (CentOs 7):
https://discourse.haproxy.org/t/segmentation-fault-on-raspberry-pi/3850
Welcome! - We kindly ask that you:
1. Fill out the issue template below - not doing so needs a good reason.
2. Use the forum or the mailing list if you have a question rather than a bug or feature request.
The forum is at: https://discourse.haproxy.org/
The mailing list (no need to subscribe) is: haproxy@formilux.org
Subscribe to the list: haproxy+subscribe@formilux.org
Unsubscribe from the list: haproxy+unsubscribe@formilux.org
Forum and mailing list are correct places for questions about HAProxy or general suggestions
and topics, e.g. usage or documentation questions! This issue tracker is for tracking bugs and
feature requests directly relating to the development of the software itself.
Thanks for understanding, and for contributing to the project!
## kernel, gcc, haproxy version and `/proc/cpuinfo`
[root@osmc haproxy]# uname -a
Linux osmc 4.14.82-v7.1.el7 #1 SMP Sun Nov 25 22:42:27 UTC 2018 armv7l armv7l armv7l GNU/Linux
[root@osmc haproxy]# gcc --version
gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-36)
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
[root@osmc haproxy]# cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2835
Revision : a02082
Serial : 00000000xxxxxxxx
[root@osmc haproxy]# ./haproxy -vv
HA-Proxy version 2.0-dev4-1713c0-5 2019/05/23 - https://haproxy.org/
TARGET = linux2628
CC = gcc
CFLAGS = -O0 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_THREAD_DUMP=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER -PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL -GETADDRINFO -OPENSSL -LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 -ZLIB -SLZ +CPU_AFFINITY -TFO -NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built without compression support (neither USE_ZLIB nor USE_SLZ are set).
Built without PCRE or PCRE2 support (using libc's regex instead)
## GDB backtrace
[root@osmc haproxy]# gdb haproxy core
Reading symbols from /root/haproxy/haproxy...done.
[New LWP 2350]
[New LWP 2349]
[New LWP 2351]
[New LWP 2348]
Core was generated by `./haproxy -f ../haproxy.cfg -d'.
Program terminated with signal 11, Segmentation fault.
#0 0x001a3730 in __ha_cas_dw (target=0x101d208, compare=0x76439d08, set=0xfffffffe) at include/common/hathreads.h:1080
1080 : "r" (*(uint64_t *)compare), "r" (*(uint64_t *)set), "r" (target)
(gdb) bt
#1 0x001a4af0 in fd_rm_from_fd_list (list=0x2ce870 <update_list>, fd=4, off=24) at src/fd.c:275
#2 0x0001635c in done_update_polling (fd=4) at include/proto/fd.h:152
#3 0x0001742c in _do_poll (p=0x2ce844 <cur_poller>, exp=0) at src/ev_epoll.c:139
#4 0x000c7ab8 in run_poll_loop () at src/haproxy.c:2546
#5 0x000c7ccc in run_thread_poll_loop (data=0x2) at src/haproxy.c:2603
#6 0x76ea0c64 in start_thread (arg=0x7643a3a0) at pthread_create.c:309
#7 0x76ddabb8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:96 from /lib/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
(gdb) bt full
previous = 8571581165952040960
tmp = 1
cur_list = {next = -1, prev = -1}
next_list = {next = -2, prev = -2}
old = 0
new = -2
prev = 1
next = 8
last = 1984144392
update_mask = 0
status = 1984142708
fd = 4
count = 0
updt_idx = 1
wait_time = 1984144392
old_fd = 4
next = 0
exp = 0
ptaf = 0x2432b0 <per_thread_alloc_list>
ptif = 0x2432b8 <per_thread_init_list>
ptdf = 0x0
ptff = 0x0
pd = 0x7643a3a0
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {1984144392, 0, 1995178472, 338, 0, 0, 1995726760, 1984143068, 1984142760, 1995050032, 0 <repeats 54 times>}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
not_first_call = <optimized out>
pagesize_m1 = <optimized out>
sp = <optimized out>
freesize = <optimized out>
No locals.
(gdb) quit
## What's the configuration?
maxconn 100
nbthread 4
timeout client 60s
timeout server 60s
listen www
bind :80
server s1 www.example.org:80
## Steps to reproduce the behavior
Start haproxy with threading enabled on a Raspberry Pi, it crashes either immediately or after a few seconds.
## Workaround
Disable threading with `nbthread 1`.
## Do you have any idea what may have caused this?
This is a regression caused by commit 6a38b3297c (`BUILD: threads: fix again the __ha_cas_dw() definition`) and also affects `1.9.8` @wtarreau
Note there is also a different threading issue reported on the ML in 1.9.8 (though probably unrelated):
https://www.mail-archive.com/haproxy@formilux.org/msg33854.html
A fix has been committed to -dev and queued up for 1.9 (will be in the 1.9.9 release):
Thanks guys, built this version and its no longer crashing:
HA-Proxy version 2.0-dev4-c3b595-33 2019/05/27 - https://haproxy.org/
mkasap
June 11, 2019, 4:37am
10
May you share your build steps for armv7 ?
I am trying to use the min version 1.9 too on Raspberry Pi
is it just:
make TARGET=custom
mkasap
June 11, 2019, 5:29am
11
this worked:
make TARGET=custom
sudo make install
pi@RPi01:~/haproxy-2.0-dev6 $ haproxy -vv
HA-Proxy version 2.0-dev6 2019/06/07 - https://haproxy.org/
TARGET = custom
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS =
Feature list : -EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE -NETFILTER -PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE -THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 -TPROXY -LINUX_TPROXY -LINUX_SPLICE -LIBCRYPT -CRYPT_H -VSYSCALL -GETADDRINFO -OPENSSL -LUA -FUTEX -ACCEPT4 -MY_ACCEPT4 -ZLIB -SLZ -CPU_AFFINITY -TFO -NS -DL -RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER -PRCTL -THREAD_DUMP -EVPORTS
Built with transparent proxy support using: IP_TRANSPARENT IP_FREEBIND
Compression algorithms supported : identity(“identity”)
Built without PCRE or PCRE2 support (using libc’s regex instead)
Built without multi-threading support (USE_THREAD not set).
Total: 2 (2 usable), will use poll.
Please don’t use make TARGET=custom unless you really know what you are doing.
Use make TARGET=linux2628 if you are an Linux (which I assume you are).
CPU=generic is fine.
