We use HAProxy to balance the load between hundreds of servers, however, there is an issue which is new for us and unexpected (works in any HAProxy version). When number of servers in some backend exceeds 100, all weights for active servers are set to zero (marked as SOFT STOPPED) and backend goes down. The only way to make backend UP again is to set server count to 100 or less. We may need to run hundreds of servers under one backed and distribute the load. How we can adjust this number?
Share the output of haproxy -vv, the configuration and explain how you add/remove servers here (are you adjusting the configuration and reloading haproxy, are you using DNS discovery, etc).
Okay, so output of haproxy -vv
HA-Proxy version 2.2.1 2020/07/23 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.2.1.html
Running on: Linux 4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u2 (2019-11-11) x86_64
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_GETADDRINFO=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with OpenSSL version : OpenSSL 1.1.1d 10 Sep 2019
Running on OpenSSL version : OpenSSL 1.1.1d 10 Sep 2019
Built with PCRE2 version : 10.32 2018-09-10
Built with gcc compiler version 8.3.0
<default> : mode=HTTP side=FE|BE mux=H1
<default> : mode=TCP side=FE|BE mux=PASS
Available services :
prometheus-exporter
[FCGI] fcgi-app
A configuration example is the next:
maxconn 100000
stats socket /var/run/haproxy.sock mode 660 level admin
debug
timeout client 50000000
timeout server 50000000
resolvers localdns
nameserver dns1 <ip>:53
accepted_payload_size 8192
hold timeout 600s
hold refused 600s
frontend http-in
bind *:8080 accept-proxy
frontend https-in
bind *:8433 accept-proxy
# Define hosts
acl host_acl hdr(host) -i <address>
# Figure out which one to use
use_backend host if host_acl
backend host
http-request set-header X-Real-IP %[src];
http-request set-header X-Forwarded-For %[src];
http-request set-header X-Forwarded-Proto %[src];
http-request set-header Connection "upgrade"
http-request set-header Host %[src]
stick-table type string len 80 size 1m expire 8h
option tcp-check
stick on url_param(mrid)
server-template srv 100 _http._tcp.<pod>.<ns>.svc.cluster.local resolvers localdns check inter 1000
As you can see, we are using DNS discovery.
Any logging happening at the same time? Could it be related to the dns response hitting the accepted_payload_size threshold?
No valuable logs. Will try to debug further today. Servers are being updated even if we have 500 of them, but with 0 weight. So, problem is definitely not in DNS Payload size, moreover 8k is the maximum here.
What usually happened when new server is added (1-100):
[WARNING] 212/080533 (7) : Server host/srv48 is UP, reason: Layer4 check passed, check duration: 0ms. 48 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Here what if happened when I add server number 101:
[ALERT] 212/080658 (7) : backend 'host' has no server available!
[WARNING] 212/080658 (7) : host/srv101 changed its IP from to <IP> by DNS additional recrd.
[WARNING] 212/080700 (7) : Server host/srv101 is UP, reason: Layer4 check passed, check duration: 0ms. 0 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
After that in 1 minute worker dies
[ALERT] 212/080908 (1) : Current worker #1 (7) exited with code 139 (Segmentation fault)
8192 bytes, not servers, and with this numbers it’s not completely unlikely that we hit it. Crossing the threshold doesn’t necessarily mean that no servers are updated, especially if we hit a bug.
A Haproxy worker is crashing here, so this is clearly a bug.
Could you file a bug:
