Setting `pool-max-conn` to `0` not closing idle connections in HAProxy 2.0
HAProxy 2.0 configuration
#maxconn 65536
http-reuse never
no log
frontend test
bind :80
maxconn 65536
default_backend nginx
backend nginx
server 10.32.95.110 10.32.95.110:81 weight 255 pool-max-conn 0 pool-purge-delay 0
server 10.32.110.236 10.32.110.236:81 weight 255 pool-max-conn 0 pool-purge-delay 0
server 10.33.238.57 10.33.238.57:81 weight 255 pool-max-conn 0 pool-purge-delay 0
When making multiple requests over 1 connection using wrk tool, connection to backend is not closed after another backend is selected as per the load balancing algorithm used. Instead old connections are kept idling and re-used when algorithm choses that server. Please let me know if this is expected.
Handled in the other thread.
