I’m having a difficult time to setup TLS termination on HAProxy,
I have HAProxy 2.6.7, I have 2 certificates for RSA and ECDSA, it is set up ad described in the docs:
bind 10.0.0.3:443 ssl crt /etc/ssl/certs/mycert.pem
ECDSA flow works:
openssl s_client -connect localhost:8883 -cipher ECDSA -CAfile ecdsa.crt -tls1_2
RSA does not
openssl s_client -connect localhost:8883 -cipher RSA -CAfile rsa.crt -tls1_2
haproxy_1 | fd[0xe] OpenSSL error[0x1417a0c1] tls_post_process_client_hello: no shared cipher
haproxy_1 | 172.18.0.1:60336 [20/Dec/2022:16:37:25.542] mqtt/1: SSL handshake failure
what could be a reason
This is the reason.
Provide the complete haproxy configuration, ciphers are likely miss-configured.
this is the global config:
ssl-default-bind-options ssl-min-ver TLSv1.2
ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384
frontend mqtt
bind *:8883 ssl crt /usr/local/etc/haproxy/local/ssl/mqp.pem
available ciphers on the host
openssl ciphers
TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:DHE-RSA-AES256-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES256-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES128-SHA:RSA-PSK-AES256-GCM-SHA384:DHE-PSK-AES256-GCM-SHA384:RSA-PSK-CHACHA20-POLY1305:DHE-PSK-CHACHA20-POLY1305:ECDHE-PSK-CHACHA20-POLY1305:AES256-GCM-SHA384:PSK-AES256-GCM-SHA384:PSK-CHACHA20-POLY1305:RSA-PSK-AES128-GCM-SHA256:DHE-PSK-AES128-GCM-SHA256:AES128-GCM-SHA256:PSK-AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:ECDHE-PSK-AES256-CBC-SHA384:ECDHE-PSK-AES256-CBC-SHA:SRP-RSA-AES-256-CBC-SHA:SRP-AES-256-CBC-SHA:RSA-PSK-AES256-CBC-SHA384:DHE-PSK-AES256-CBC-SHA384:RSA-PSK-AES256-CBC-SHA:DHE-PSK-AES256-CBC-SHA:AES256-SHA:PSK-AES256-CBC-SHA384:PSK-AES256-CBC-SHA:ECDHE-PSK-AES128-CBC-SHA256:ECDHE-PSK-AES128-CBC-SHA:SRP-RSA-AES-128-CBC-SHA:SRP-AES-128-CBC-SHA:RSA-PSK-AES128-CBC-SHA256:DHE-PSK-AES128-CBC-SHA256:RSA-PSK-AES128-CBC-SHA:DHE-PSK-AES128-CBC-SHA:AES128-SHA:PSK-AES128-CBC-SHA256:PSK-AES128-CBC-SHA
haproxy -vv
root@prism:/# haproxy -vv
HAProxy version 2.6.7-c55bfdb 2022/12/02 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2027.
Known bugs: http://www.haproxy.org/bugs/bugs-2.6.7.html
Running on: Linux 5.10.104-linuxkit #1 SMP Thu Mar 17 17:08:06 UTC 2022 x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_GETADDRINFO=1 USE_OPENSSL=1 USE_LUA=1 USE_PROMEX=1
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL +THREAD +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -ENGINE +GETADDRINFO +OPENSSL +LUA +ACCEPT4 -CLOSEFROM -ZLIB +SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL -PROCCTL +THREAD_DUMP -EVPORTS -OT -QUIC +PROMEX -MEMORY_PROFILING
Built with multi-threading support (MAX_THREADS=64, default=8).
Built with OpenSSL version : OpenSSL 1.1.1n 15 Mar 2022
Running on OpenSSL version : OpenSSL 1.1.1n 15 Mar 2022
[FCGI] fcgi-app
certificate loaded as:
and in
- mqp.pem.ecdsa
- mqp.pem.rsa
echo 'show ssl cert' | socat unix-connect:/var/run/haproxy.sock stdio
# filename
/usr/local/etc/haproxy/local/ssl/mqp.pem.ecdsa
/usr/local/etc/haproxy/local/ssl/mqp.pem.rsa
anything else will be helpful?
When instructing openssl to use RSA
ciphers, you are restricting openssl to only a few RSA ciphers:
lukas@dev:~$ openssl ciphers 'RSA'
TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:AES256-GCM-SHA384:AES256-CCM8:AES256-CCM:ARIA256-GCM-SHA384:AES128-GCM-SHA256:AES128-CCM8:AES128-CCM:ARIA128-GCM-SHA256:AES256-SHA256:CAMELLIA256-SHA256:AES128-SHA256:CAMELLIA128-SHA256:NULL-SHA256:AES256-SHA:CAMELLIA256-SHA:AES128-SHA:SEED-SHA:CAMELLIA128-SHA:NULL-SHA:NULL-MD5
None of those match the RSA ciphers you put into your haproxy config, because RSA
does not cover ECDHE (RSA) ciphers you configured in haproxy:
So your test command needs to be:
openssl s_client -connect localhost:8883 -cipher ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384 -CAfile rsa.crt -tls1_2
You could also specify aRSA
instead of RSA
, as per /docs/man1.1.1/man1/ciphers.html
To be more precise, as per the openssl manual:
RSA is an alias for kRSA; but with ECDHE ciphers RSA is not used for key exchange, ECDHE is, so thats why kRSA does not imply ECDHE-RSA.
In ECDHE-RSA RSA is only used for authentication, which is why aRSA
is the correct keyword.
sorry, I forgot to mention this as well, I did the test with specific ciphers, the same as you did, was the same result, so far I’m really puzzled. Is there a way to instruct haproxy to produce more diagnostics from openssl?
No, I don’t think so, haproxy already provides the error that OpenSSL returns, there is nothing more that haproxy could provide in this case.
Try sigalgs as opposed to ciphers (or try both) in the client, this is more appropriate to simulate a RSA only speaking client:
-sigalgs "RSA-PSS+SHA512:RSA-PSS+SHA384:RSA-PSS+SHA256:RSA+SHA512:RSA+SHA256:RSA+SHA384:RSA+SHA224:RSA+SHA1"
