My scenario is as follows:
I have a single server with multiple domains. For each domain I’d like to have a separate docker container (won’t go into reasons why I want this, but it does make sense) as an email server (postfix + dovecot). I’ve researched this extensively for months and believe this should be possible using haproxy.
I’d like to achieve this without ssl termination - basically using pass-though or in other words, read the TLS SNI header (domain) and decide based on that which upstream to forward the traffic to.
Something like this is even described on: https://www.haproxy.com/blog/enhanced-ssl-load-balancing-with-server-name-indication-sni-tls-extension/
I’m not sure if I’ve configured something wrong or am I completely missing something here?
If I set a default server, this works, but proxying based on domain (sni) does not.
My configuration is as follows:
timeout client 30s
timeout server 30s
frontend smtp_submission
bind *:587
use_backend smtp_submission
frontend imap
bind *:993
use_backend imap
acl mail_domain1_match req_ssl_sni -i smtp.domain1.com
acl mail_domain2_match req_ssl_sni -i smtp.domain2.com
use-server mail_domain1_smtp_submission if mail_domain1_match
use-server mail_domain2_smtp_submission if mail_domain2_match
option ssl-hello-chk
server mail_domain1_smtp_submission 172.17.0.12:587 weight 0
server mail_domain2_smtp_submission 172.17.0.11:587 weight 0
backend imap
acl mail_domain1_match req_ssl_sni -i imap.domain1.com
acl mail_domain2_match req_ssl_sni -i imap.domain2.com
use-server mail_domain1_imap if mail_domain1_match
use-server mail_domain2_imap if mail_domain2_match
server mail_domain1_imap 172.17.0.12:993 weight 0
server mail_domain2_imap 172.17.0.11:993 weight 0
