My 1st topic here, so bear with me ![]()
My current (working) setup is fully end2end encrypted.
Meaning my frontend does TLS offloading, and then reencypts all traffic to the backend.
Another thing we do is rewrite the host headers to whatever request url was sent to the server. All of this works great.
Now what happens is that to the frontend all traffic is either HTTP/2 or lower.
To the backend (IIS 10 on Server 2022) all traffic is Http 1.1 (or lower).
I wanted to see if HTTP/2 to the backend is a possibility and check what the impact would be on our webservers/ application.
So what I tried was adding alpn h2,h1 to a server line. However this immediately results in a Socket error for that server
I have verified that on the IIS webserver connecting to localhost, I do get HTTP/2 connections. What I’ve also tried was disabling the Healthchecks from HAProxy and force the site to be up. That also works, and then traffic is then coming in on IIS as HTTP/2.
So I figured it might have something to do with the healthcheck…
For reference this is my config (sanitized).
maxconn 10000
option httpslog
timeout client 300s
timeout server 300s
frontend fe_main_tcp
option tcp-smart-accept
bind :80,:443
tcp-request inspect-delay 10s
tcp-request content track-sc0 capture.req.ver table st_http_stats
default_backend be_maintcp
backend be_maintcp
option tcp-smart-connect
server fe_acceptweb abns@haproxy send-proxy-v2
frontend fe_acceptweb
maxconn 1000
option httpslog
bind abns@haproxy ssl crt /etc/haproxy/certs ssl-min-ver TLSv1.2 alpn h2 accept-proxy
acl allowed_method method GET HEAD POST PUT DELETE OPTIONS SSTP_DUPLEX_POST
http-request set-header X-Forwarded-Port 443
default_backend be_web
backend be_web
option httpchk
http-check send hdr Host webserver.local
default-server ssl verify none check-sni webserver.local check sni str(webserver.local) on-marked-down shutdown-sessions
http-request set-header X-Forwarded-Host %[req.hdr(Host)]
http-request set-header Host webserver.local
server WEB01 10.0.1.2:443
So something is happening that I don’t understand, I figured adding alpn should be enough but that does not seem to work as I had expected. Since IIS seems to be able to serve HTTP2 I am leaning to an issue with HAProxy.
I used the Haproxy version 2.6 and 2.5.7 to check, but both have the same issue.
Hope someone is familiar with or has ran into a similar issue
