I am using an action, from where I will connect with external server and return an action. I written using lua and used api httpclient or socket. Everything works fine without SSL.
But for the production system, I need to make this API’s to work with SSL. I need to understand how to use the cert.pem security file to make this work with the HAProxy action.
Below are the code snippets.
HaProxy.cfg
log /dev/log local0 debug
lua-load /etc/haproxy/ipchecker.lua
httpclient.ssl.ca-file /etc/ssl/certs/cert.pem
httpclient.ssl.verify none
timeout connect 20s
timeout client 30s
timeout server 30s
timeout http-request 30s
timeout http-keep-alive 2m
timeout queue 15s
timeout tunnel 4h # for websocket
frontend fe_main
bind *:80 v4v6
http-request scheme https lua.checkip 127.0.0.1 5000
http-request deny if { var(req.blocked) -m bool }
default_backend be_servers
backend be_servers
server server1 127.0.0.1:666 check maxconn 30
my lua file
– The contents of this file are Copyright (c) 2019. HAProxy Technologies. All Rights Reserved.
– This file is subject to the terms and conditions defined in
– file ‘LICENSE’, which is part of this source code package.
local function check_ip(txn, addr, port)
if not addr then addr = ‘127.0.0.1’ end
if not port then port = 5000 end
local hdrs = {
[1] = string.format('host: %s:%s', addr, port),
[2] = 'accept: */*',
[3] = 'connection: close'
local httpclient = core.httpclient()
local response = httpclient:get{url="http://127.0.0.1:5000/", headers=hrds}
for key, value in pairs(response.headers) do
if (type(value) == "table") then
-- do stuff
for key1, value1 in pairs(value) do
core.log(core.notice, string.format("\"%s\":%s", key, value1))
end
else
-- do other stuff instead
core.log(core.notice, string.format("\"%s\":%s", key, value))
end
end
core.log(core.notice, string.format("Called Ananda dadsdsdsddsds %d %s %s", response.status, response.reason,
response.body))
if response.body and response.body == ‘allow’ then
txn:set_var(‘req.blocked’, false)
return
end
-- Set up a request to the service
--[[local hdrs = {
local req = {
[1] = string.format('GET / HTTP/1.1'),
[2] = table.concat(hdrs, '\r\n'),
[3] = '\r\n'
req = table.concat(req, '\r\n')
-- Use core.tcp to get an instance of the Socket class
local socket = core.tcp()
socket:settimeout(5)
core.log(core.notice, string.format("Called Ananda dadsdsdsddsds --> %s", req))
-- Connect to the service and send the request
if socket:connect(addr, port) then
if socket:send(req) then
– Get response body, if any
while true do
local line, _ = socket:receive(‘*l’)
core.log(core.notice, string.format(“headers → %s”, line))
if not line then break end
if line == ‘’ then break end
end
local content = socket:receive('*a')
core.log(core.notice, string.format("resp --> %s", content))
-- Check if this request should be allowed
if content and content == 'allow' then
txn:set_var('req.blocked', false)
return
end
else
core.Alert('Could not connect to IP Checker server (send)')
end
socket:close()
else
core.Alert('Could not connect to IP Checker server (connect)')
end]]
-- The request should be blocked
txn:set_var('req.blocked', true)
end
core.register_action(‘checkip’, {‘http-req’}, check_ip, 2)
