Hi, I’m trying to figure out if HA Proxy could be used in the way I want it to.
I have a simple REST API running on localhost:8080 and I want to use HA Proxy to add SSL support. I already have all the certificates in place and haproxy seems to run without problems. But every time I try to invoke my API over HTTPS I get a 109 error (Network unreachable) because I think it’s looking for my backend server running on port 443 but there’s no SSL there.
Here’s my config at the moment (I tried many different configurations):
stats uri /haproxy?stats
frontend http_front
bind *:443 ssl crt /etc/ssl/certs/server.bundle.pem
default_backend http_back
backend http_back
server my-api 127.0.0.1:8080 check ssl verify none
Any help will be much appreciated!
Cheers,
Gabriel.
