I am working on a setup where there are two HAProxies behind an AWS Network load balancer. Behind the HAProxy are apache web servers. I am passing ssl traffic from the NLB to HAProxy and then SSL offloading is taking place on HAProxy. Requests are working as expected. However the log files are getting flooded with the following messages.
Another weird part is its not happening all the time. But when its hapenning, the log is getting flooded.
Reload/Restart seems to solve it temporarily.
Following is the output of haproxy -vv
HA-Proxy version 2.0.2-1~bpo10+1 2019/07/17 - https://haproxy.org/
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-2.0.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
Built with multi-threading support (MAX_THREADS=64, default=8).
Built with OpenSSL version : OpenSSL 1.1.1c 28 May 2019
Running on OpenSSL version : OpenSSL 1.1.1b 26 Feb 2019
Built with PCRE2 version : 10.32 2018-09-10
h2 : mode=HTTP side=FE mux=H2
<default> : mode=HTX side=FE|BE mux=H1
<default> : mode=TCP|HTTP side=FE|BE mux=PASS
Available services :
prometheus-exporter
Also, is there any chance that this can impact SSL offload time
