Hi ,
I would like to have ssl -pass thru working for my env.
from my random read on internet and this side, i understand that i need to use “mode tcp” for ssl-passtru to work. on the fronend, i do lot of filtering by using ACLs , which mostly works with http mode, and i don’t want to lose this flexibility. I read from thread <(TCP with ACL possible?)> that it is possible to use http mode in front end and tcp mode in backend.
But with that i am getting error as:-
http frontend ‘web_gateway’ (/usr/local/etc/haproxy/haproxy.cfg:48) tries to use incompatible tcp backend ‘otntomcat’ (/usr/local/etc/haproxy/haproxy.cfg:166)
Can you please let me know how it (ssl-passthru) can be done without losing the http mode flexibility?
Thanks a lot.
The haproxy.cfg (shortened one…) is as below.
user otn
group otn
master-worker
backlog 4096
timeout client 200s
timeout client-fin 20s
timeout server 100s
timeout tunnel 15m
timeout http-keep-alive 30s
timeout http-request 10s
timeout queue 5s
timeout tarpit 60s
maxconn 10000
default-server inter 3s rise 2 fall 3 init-addr last,libc,none
frontend default_ports
bind *:80 user otn group otn
http-request redirect location https://"$ipv4addr":"$port"/cas/login
frontend default_ports_443
bind *:443 user otn group otn ssl crt /usr/local/etc/haproxy/cert.crt
acl fault_path path_beg -i /FaultManagement
use_backend nspos_serv1 if fault_path
default_backend nspos_serv
frontend web_gateway
bind *:"$port" ssl crt /usr/local/etc/haproxy/cert.crt
http-request set-query %[query,regsub(:"$port",g)]
http-request set-uri %[url,regsub(otntomcat,"$ipv4addr",g)]
acl otntomcat_path path_beg -i /oms1350
acl dojoroot_path path_beg -i /dojoroot
acl p1 path_beg -i /jointroot
acl p2 path_beg -i /jquery
acl p3 path_beg -i /lodash
acl p4 path_beg -i /openlayersroot
acl p5 path_beg -i /search
acl p6 path_beg -i /svgutilsroot
acl p7 path_beg -i /d3root
acl p8 path_beg -i /backbone
acl p9 path_beg -i /Cpb
use_backend otntomcat if otntomcat_path || dojoroot_path || p1 || p2 || p3 || p4 || p5 || p6 || p7 || p8 || p9
acl cas_path path_beg -i /cas
acl session_path path_beg -i /session-manager
use_backend nspos_serv if cas_path || session_path
acl int_path path_beg -i /internal
use_backend nspos_serv if int_path
acl ntsm_path path_beg -i /ntsm
use_backend ntsm_serv if ntsm_path
acl systemmonitor_path path_beg -i /systemmonitor
use_backend systemmonitor_serv if systemmonitor_path
acl wso_path path_beg -i /wso
use_backend wso_serv if wso_path
acl motn_path path_beg -i /onc
use_backend motn_serv if motn_path
acl nrct_tapi_path path_beg -i /tapi
use_backend nrct_tapi_serv if nrct_tapi_path
resolvers docker_nfmt-net
nameserver dns1 127.0.0.11:53
backend otntomcat
log stdout local0 debug
server serv01 otntomcat:8443 resolvers docker_nfmt-net check ssl verify none
http-response replace-header Location (.)(\botntomcat\b)(.)$ \1"ipv4addr"\3
http-response replace-header Location (.*)(\b80\b)(.*) \1"port"\3
http-response replace-header Location (.*)(\b443\b)(.*) \1"port"\3
http-response replace-header Location (.*)(\b8544\b)(.*) \1"port"\3
http-response replace-header Location (.*)(\b8545\b)(.*) \1"port"\3
http-response replace-header Location (.*)(\b8443\b)(.*) \1"$port"\3
http-response replace-header Location (.)(\b/oms1350/pages/otn\b)(.) \1:"$port"/oms1350/pages/otn\3
http-response replace-header Location (.)(\b/oms1350/login/cas\b)(.) \1:"$port"/oms1350/login/cas\3
bind *:1974
stats uri /
