I have haproxy configured with around 74 backends each using `server-template name ${FDQN}" for my backends. The haproxy nodes are containers in a small k8s cluster.
I’m fine with the IP addresses getting re-discovered and shuffled but the logs are choking my log aggregation and I can’t seem to squelch them in haproxy with any combination of log parameters in global. It’s over 9,000 lines/minute per container in my k8s cluster.
Is there a way to hide these warnings (example below)?
haproxy-local | [WARNING] 082/114612 (8) : account_service/account_service changed its IP from 123.456.789.123 to 123.456.789.123 by k8s_dns/dns.
haproxy-local | account_service/account_service_1 changed its IP from 123.456.789.123 to 123.456.789.123 by k8s_dns/dns.
Is there a way to hide/squelch or prevent these messages from popping up every second? The only thing I could think of was tuning the k8s_dns k8s_dns to have much higher hold values but then I end up with old cached entries in haproxy and services going offline during deployments. Is there a way to hide these DNS change logs while keeping my resolver hold values low?
I forgot to include version info:
haproxy 2.2.4
