Struggles with Stick-table string
Im having a bit of an issue blocking based on a token. My intention is to allow a token specified in the url. To be allowed only once. (in the below example per hour)
It’s a http backend, my original config is quite long so for clearness decided to post the most relevant part.
backend be_remote from http_frontend
    default-server ssl verify none
    server remoteapp 192.168.36.18
    acl token_reuse sc1_inc_gpc1(be_remote) gt 0
    stick-table type string len 120 size 100k expire 1h store gpc0
    http-request track-sc1 url_param(token)
    http-request deny if { url_param(token),table_gpc1(be_remote) gt 1 }
My stick table gets filled just fine. (And I can likely get away with len 64), but after a day of trying almost everything…
table: be_remote, type: string, size:102400, used:1
0x1815faaa4488: key=CBD4B86D34CA070BC6984DCE0FDFC41795D1ABFC199607650257EC3752A9E5C7 use=3 exp=3591138 shard=0 gpc0=0
This is a actual token, but they invalidate soon enough.
The above works for a large part except it does not block requests, my intention is that a second or more http request containing the same token should be blocked.
for completeness we call this with
https://<url>/rdp/#/client/NwBjAG15c3Fs?token=CBD4B86D34CA070BC6984DCE0FDFC41795D1ABFC199607650257EC3752A9E5C7
Now I’m thinking that the comparison is maybe to blame because we use a string, but I cant find any examples or similar configs. (plenty with ip src etc counters, but almost none with string).
Can someone tell me why this does not work? I figured perhaps it was an issue that the traffic was already flowing and thus it might not be blocked anymore, so I moved the deny logic to a http_frontend, but same issue, hence my suspection of it being related to the data being stored as a key=value.
Hope someone can help me out
I’ve partially figured it out. The config does work, however it just blocks the websocket creation, the application used, swallows that and fails back to http only.
I did learn something new, and the idea I had will simply not work. Web applications is not my area of expertise, but I do have a new appreciation for web developers :slight_smile:
