We currently run 2.8.10 in production . A beautiful version, built like this ….
HAProxy version 2.8.10-1ppa1~jammy 2024/06/16 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2028.
Known bugs: http://www.haproxy.org/bugs/bugs-2.8.10.html
Running on: Linux 6.5.0-1025-azure #26~22.04.1-Ubuntu SMP Thu Jul 11 22:33:04 UTC 2024 x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -O2 -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
OPTIONS = USE_OPENSSL=1 USE_LUA=1 USE_SLZ=1 USE_SYSTEMD=1 USE_OT=1 USE_QUIC=1 USE_PROMEX=1 USE_PCRE2=1 USE_PCRE2_JIT=1 USE_QUIC_OPENSSL_COMPAT=1
Note the use of the build option USE_SYSTEMD=1
This ties up with the recommendation in the 2.8 docs.
-Ws : master-worker mode with support of `notify` type of systemd service.
This option is only available when HAProxy was built with `USE_SYSTEMD`
build option enabled.
We notice our ExecReload uses -Ws
However when we look at our 3.2.3 version we do NOT have that build option..... see below
HAProxy version 3.2.3-2ppa1~noble 2025/07/11 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2030.
Known bugs: http://www.haproxy.org/bugs/bugs-3.2.3.html
Running on: Linux 6.11.0-1018-azure #18~24.04.1-Ubuntu SMP Sat Jun 28 04:46:03 UTC 2025 x86_64
CC = x86_64-linux-gnu-gcc
CFLAGS = -O2 -g -fwrapv -g -O2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -ffat-lto-objects -fstack-protector-strong -fstack-clash-protection -Wformat -Werror=format-security -fcf-protection -fdebug-prefix-map=/build/haproxy-CziFcf/haproxy-3.2.3=/usr/src/haproxy-3.2.3-2ppa1~noble -Wdate-time -D_FORTIFY_SOURCE=3
OPTIONS = USE_OPENSSL=1 USE_LUA=1 USE_SLZ=1 USE_OT=1 USE_QUIC=1 USE_PROMEX=1 USE_PCRE2=1 USE_PCRE2_JIT=1 USE_QUIC_OPENSSL_COMPAT=1
DEBUG =
Why is this important ?
WELL : THe 3.2 documentation makes no mention of a requirement for the USE_SYSTEMD build option anymore.
-W : master-worker mode. It is equivalent to the "master-worker" keyword in
the "global" section of the configuration. This mode will launch a "master"
which will monitor the "workers". Using this mode, you can reload HAProxy
directly by sending a SIGUSR2 signal to the master. The master-worker mode
is compatible either with the foreground or daemon mode. It is
recommended to use this mode with multiprocess and systemd.
Question is : is the documentation correct, and probably even more importantly should we still use ExecReaload with -Ws or should we be doing -W or does it not matter.
What is the correct path to follow here ?
Regards,
