TCP failover with open connection
Hi community.
I am running a simple test for TCP failover using nc:
nc -klv 6001
nc -klv 6002
to listen on both ports specified in the backend and then I run
[opc@virutal-prod haproxy]$ nc localhost 6000
msg1
msg2
to send message which all go to 6001 which is fine. But when I kill the nc on 6002 I get:
msg1
msg2
msg3
msg4
Ncat: Broken pipe.
I get a broken pipe. When rerun nc localhost 6000, it connects correctly to 6002.
My question is if it is expected to get a broken pipe or should the existing TCP connection have been relocated from to server on 6001 to the server running on 6002?
HAProxy config is:
    mode                    tcp
    option                  tcplog
    retries                 3
    timeout http-request    10s
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout server          1m
    timeout http-keep-alive 10s
    timeout check           10s
    maxconn                 3000
frontend main
    bind *:6000
    default_backend             app
backend app
    balance     roundrobin
    server  app1 127.0.0.1:6001 check on-marked-down shutdown-sessions on-marked-up shutdown-backup-sessions
    server  app2 127.0.0.1:6002 check backup
