What I’d like:
- one frontend section (e.g. bound to port 80)
- two backends
- the first one is “static files” served over HTTP
- the second one is a TCP response generation service that let’s users generate responses based on HTTP request, e.g.
ANYTHING /response/{base64-encoded response}- mostly used for testing HTTP responses, but can respond with any arbitrary bytes not conforming to HTTP (so a raw TCP stream) to test out clients handling faulty “HTTP” responses
Problem:
- how to proxy requests based on the magic string
/response/- if it is encountered in e.g. the first 50 bytes of the TCP stream, instantly use the response generation backend; otherwise, serve static files from the first backend - the overall request (especially for the service) may be shorter than 50 bytes
- it should be as fast as possible, but also deal with somewhat slower clients or lost packets (e.g. TCP handshake made, but some time to get the first data packets flowing in)
Current test set-up - I can get the needed condition working with either an arbitrary delay (not wanted! do it as fast as possible, but have a timeout) or “reject/accept” instantly, but then no choice can be made between backends.
haproxy.cfg:
log stdout format raw local0
timeout connect 28s
timeout client 29s
timeout server 30s
frontend fe_main
bind :80
tcp-request inspect-delay 3s
# OPTION 1: it works, but delay is necessary (otherwise acl not enforced)
tcp-request content accept if WAIT_END
acl contains_bbb req.payload(0,0) -m sub BBB
use_backend be_data if contains_bbb
# (Almost an) OPTION 2: it works instantly, but can't choose backends this way
# tcp-request content reject if { req.payload(0,0) -m sub AAA }
default_backend be_static
backend be_data
server server1 data_backend:9001
backend be_static
server server1 static_backend:9002
docker-compose.yml:
services:
haproxy:
image: haproxy:3.0
volumes:
- ./haproxy.cfg:/usr/local/etc/haproxy/haproxy.cfg:ro
ports:
- "80:80"
depends_on:
- data_backend
- static_backend
data_backend:
image: alpine/socat
command: "tcp-l:9001,fork,reuseaddr exec:/bin/cat"
static_backend:
image: alpine/socat
command: "tcp-l:9002,fork,reuseaddr exec:'/bin/echo -e HTTP/1.1 200 OK\\r\\n\\r\\nbody'"
Build:
$ docker compose up --build --force-recreate
Test:
$ printf "BBB" | nc localhost 80
$ printf "BBB" | nc localhost 80 # when have chosen the 2nd option
