Tcp Proxy tls Handshake after 12 hours
Hí my name is Adam, im implementing an proxy for a service routing mqtt trafic to a rabbitmq server (Message broker).
Everything is correct at begining but after a few hours, the service start handling an Handshake error.
the port is listening whit tls and mutuals tls verification.
Here is my configuration:
log stdout format raw local0 info
ssl-default-bind-options ssl-min-ver TLSv1.0
log     global
mode    http
option  tcplog
option  dontlognull
timeout connect 1m
timeout client  1m
timeout server  1m
frontend rabbitui-frontend
bind *:8080 ssl crt-ignore-err all crt /etc/ssl/certs/tls.pem verify none
default_backend rabbitui-backend
frontend rabbittcp-frontend
bind *:8081 ssl crt-ignore-err all crt /etc/ssl/certs/tls.pem verify required ca-file /etc/ssl/certs/ca.pem crl-file /etc/ssl/certs/crl.pem
default_backend rabbittcp-backend
server s1 ${RABBITMQ_HOST}:15672
server s1 ${RABBITMQ_HOST}:5672
Can you share haproxy logs when this happens? I don’t see any maxconn configuration, you should set maxconn in global/frontend and on the individual servers in the backend.
