Hello, i have a gameserver. Multiple game instance working on same server with different ports.
for example
game 1 : ip:20001
game 2 : ip:20002
games deault port is : 2000. if anyone want to connect to this servers they must we write a port after ip because it’s not working on default port.
Can i redirect this traffic to different ports by domain name.
For example HAProxy listen game’s default port 2000.
If client trying to connect abc.com:2000 haproxy redirect this traffic to 127.0.0.1:2001
if try do abcd.com:2000 haproxy redirect this traffic to 127.0.0.1:2002
Is it possible, if yes how can i do it ?
Thank you.
Only with HTTP or HTTPS. Not with a proprietary protocol (like a game server), unless:
- the client talks first
- that first packet contains the hostname on a fixed offset which you can match with payload or payload_lv [1]
Also most of the game servers actually use UDP for the game synchronization, and only use TCP for setup and things like chats or statistics.
[1] https://cbonte.github.io/haproxy-dconv/1.7/configuration.html#7.3.5-payload
We could say that with TLS you could achieve the desired setup, right? As the client would advertise the desired host via SNI.
That depends on the application. A browser will always add SNI to the TLS hello, but that doesn’t mean other applications do the same. They may or may not.
Got it, that makes sense.
I took a look at the RFCs again, I forgot that it is an extension that may be used.
Thanks, Lukas!
